In the “usb hostlite fat32 implementation forum No. 20503 I am a bit confused. Which routine should I be using f_open() or FILE_Open? If I use FILE_Open (as subsequent code in the thread indicates) then how does the BOOT_SEC structure get populated because FAT_Init() is no longer used and f_mount() doesn’t do this for me. Thank you for any support.
Yes, of course. http://www.keil.com/forum/20503/
Sorry.
Wouldn't it help if you supplied a link to that thread?
