Some Help for ARM7 LPC2148 UART0??
Hello!!! i just purchased a new ARM7 bases LPC2148 Development Board, it is having on chip crystal of 12Mhz
As i don't know the Clock on which my controller is executing can any one tell me that what is the instruction cycle timing for my board and how to evaluate this.
Here is my Startup.s file in Keil UVision IDE
www.edaboard.com/.../79624d1346723074-startup_file.png
Some one please explain me this, as i have to calculate the value of U0DLM and U0DLL
I my example program that comes with my development board, the Serial Port Initialization code is given.
which is as follow:-
Code:
void init_serial (void) {
PINSEL0 = PINSEL0 | 0X00000005;
U0LCR = 0X83; /*8 bits, no Parity, 1 Stop bit */
U0DLL = 0XC3;
U0DLM = 0X00;
U0LCR = 0X03;
I didn't get the meaning of this line
PINSEL0 = PINSEL0 | 0X00000005; /* Enable RxD0 and TxD0 */
Can any one help me regarding all this..
How to determine the clock of my board and the meaning of above line..
Thanks in advance
  • Hi,
    means enabling the function of Pin0.19 & Pin0.21 as TxD0 & RxD0; ORing is done in order to select just only the specified bits of PINSEL0 Register & not altering the other bits of PINSEL0. PINSEL0 Register is used to select the other function of the pins other than GPIO.
    Please read the datasheet
    You can know your PCLK by a simple formula if you are an engineer
    baudrate = PCLK/16(U0DLM + U0DLL)
  • Hi,
