Is there a complete description of the AGSI interface? I am currently examining http://www.keil.com/appnotes/docs/apnt_196.asp and http://www.keil.com/appnotes/docs/apnt_154.asp (which are basically the same) and finding that some features are poorly or not at all documented.
For example:
AgsiEntry ... AGSI_PRERESET Not Used Called before Reset, but CPU cycles still valid AGSI_CMDOUT Pointer to Text Command output of 'exec' commands AGSI_ONINTERRUPT Pointer to Interrupt Number Interrupt from a device AGSI_ONRETI Pointer to Interrupt Number Interrupt acknowledged AGSI_ENTERSLEEP Not Used Power down mode entered AGSI_EXITSLEEP Not Used Power down mode exited
What are the "'exec' commands"? What is the type of the "Interrupt Number"? What should AgsiEntry() return in any of these cases? (In the code sample it always returns TRUE, but what happens if it returns FALSE?) etc
Sandy
