Hi all,
I am interfacing a 16-bit ADC to my arm MCU and I want to filter out noise. I have performed the steps below using the ARM DSP library and I want to ensure that I am doing stuffs correctly so thanks in advance to correct me if I am wrong:
1. Get the adc samples in a Q15 buffer
1. Convert the adc samples from Q15 to float using "arm_q15_to_float"
2. filter the ADC samples using a fir filter (the filter uses float) using "arm_fir_f32"
3. Convert the adc samples from folat to Q15 using "arm_float_to_q15"
4. Output the samples on DAC (just to check that noise was filtered)
Do you have a comment or a suggestion for enhancement?
INSATien
Does your processor have floating point support?
If not, then it might be a good idea to just play with integers all the way instead of jumping to floating point. Fixed-point arithmetic can do magic.
Yes, I am using STM32 cortex M4 inside with FPU enabled.
Thanks alot
