incorrect hex generation from keil (no values for jump addresses)
hi i am using keil uVision3. i have written a simple code in assemply language which contains jump instructions like sjmp,jnz jb . when i generate the hex file from this asm file all the other values in the hex file are correct except for the jump addresses corresponding to these instructions
my asm file is as follows
reset: ljmp start nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop nop
start: mov A,#00h
-- mov P0,#0ffh
-- mov P1,#0ffh
-- jb p1.0,jump1
jump1: jnz jump2
-- mov a,P0
-- mov R0,a
-- mov a,#00h
-- inc a
-- ret
jump2: mov a,P0
-- mov R1,a
-- sjmp jump3
-- ret
jump3: mov A,R1
-- add A,R0
-- mov P0,A
-- clr P1.2
-- setb P1.2
-- clr P1.2
-- ret
-- end
(i have used "--" for formatting this msg its not part of actual .asm file )
and the hex file i get is like this
:1000000002001D00000000000000000000000000D1
:1000100000000000000000000000000000740075F7
:1000200080FF7590FF2090007007E580F874000451
:1000300022E580F9800122E928F580C292D292C29D
:0200400092220A
:00000001FF
here u can see that hex corresponding to jb is 20 (3rd line) after that address of port p1.0 which is 90 but the address that it should jump comes out to be 00 which is incorrect.
the address should be 28(hex)
{you can calculate the address by writting one byte per line or generate a dua file from the hex file}
please tell me if i am missing out on something.......and tell me how to generate a correct hex file
  • when i generate the hex file from this asm file all the other values in the hex file are correct except for the jump addresses corresponding to these instructions
    Actually the only thing incorrect here is your belief that you know what those jump addresses should look like in a hex file.
    I suggest that next time you feel like blaming somebody else's work to be faulty, you make you sure you got your facts straight first.
