Not sure if this question should be for SiLabs or Keil, but hope someone here can help.
I'm using PK51 uVision4 with Si Labs C8051Fxxx Driver, but cannot see any of the Peripherals. A friend who has an older version, uVision2, can see the Peripherals without any problem. I contacted Keil support, I was told that they couldn't see the Peripherals on uV4 either. They suggested I get a couple of DLL files from my friend and replace mine with them to see if that'll help. I replaced the following files with the ones from uV2:
DCYG.DLL TCYG.DLL SiC8051F.DLL
but that did not help either. Any idea what I can do to fix this? Thanks.
