I am using LPC2478(ARM7) for my Application. I have to store my data in Internal flash in run time. I am trying this functionality by using IAP.
Is it a right approach? Is there any other way of writing to Internal Flash. when I want to use IAP I have to disable my Interrupts. This is degrading the system functionality
Please suggest me a solution. Thanks in Advance
Thanks & Regards, E.SundarRajan +91-8904468284
Just make sure you don't get issues with the supported number of flash sector rewrites. Storing configuration in the flash should normally work well, but storing log data or similar may result in too many writes for a full product life cycle.
Hi Mark,
Thank you for the reply
My requirement is not a continuous update, It is similar to Storing the Configuration.
Please let me know:
Is there any way to write directly to flash without calling the IAP function. If my Sectors are well defined
The IAP is the official interface for doing the writes. How would you know how to take into account, processor clock frequency, temperture and operating voltage? What do you think there is to gain by having to duplicate the functionality that is already available?
