Multiple mailbox
I'm trying to use multiple maibox for communication between a parent task to other tasks daughters.
But my parent task can only communicate with a single child task, after which the system seems to stop.
/* Struct messages */
struct mbx_messages {
  u8 cmd, ok;
  u8 pack[10];
/* Mailbox declarations */
os_mbx_declare(mbx_task_master, 1);
os_mbx_declare(mbx_task_slave_1, 1);
os_mbx_declare(mbx_task_slave_2, 1);
/* Memory pool */
_declare_box(mbx_pool, sizeof(struct mbx_messages), 6);
/* Master task */
__task void master_task(void)
  struct mbx_messages *snd_msg, *rcv_msg;
  os_dly_wait(4);
  while(1)
    os_dly_wait(4);
    if(uart_2_read_byte() == 'S')
      if(os_mbx_check(&mbx_qtotalizer_sweepfp) != 0)
        snd_msg = _alloc_box(mbx_pool);
        snd_msg->cmd = 1;
        os_mbx_send(&mbx_task_slave_1, snd_msg, 10);
        if(os_mbx_wait(&mbx_task_master, (void *)&rcv_msg, 10) != OS_R_TMO)
          if(rcv_msg->cmd == 2)
            snd_msg->cmd = 3;
            os_mbx_send(&mbx_task_slave_2, snd_msg, 10);
              if(rcv_msg->cmd == 4)
                uart_2_write_str("cmd = 4\n");
          else
            uart_2_write_str("cmd != 2\n");
        _free_box(pool_sweepfp, rcv_msg);
/* Slave 1 task */
__task void slave_1_task(void)
  os_dly_wait(4);
  while(1)
    if(os_mbx_wait(&mbx_task_slave_1, (void *)&rcv_msg, 10) != OS_R_TMO)
      if(rcv_msg->cmd == 1)
        snd_msg->cmd = 2;
      else
        uart_2_write_str("cmd != 1\n");
      os_mbx_send(&mbx_task_master, snd_msg, 10);
/* Slave 2 task */
__task void slave_2_task(void)
  os_dly_wait(4);
  while(1)
    if(os_mbx_wait(&mbx_task_slave_2, (void *)&rcv_msg, 10) != OS_R_TMO)
      if(rcv_msg->cmd == 3)
        snd_msg->cmd = 4;
      else
        uart_2_write_str("cmd != 4\n");
/* Boot task */
__task void boot_task(void)
  uart_2_open(9600);
  _init_box(mbx_pool, sizeof(mbx_pool), sizeof(struct mbx_messages));
  os_mbx_init(&mbx_task_master, sizeof(mbx_task_master));
  os_mbx_init(&mbx_task_slave_1, sizeof(mbx_task_slave_1));
  os_mbx_init(&mbx_task_slave_2, sizeof(mbx_task_slave_2));
  os_tsk_create(master_task, 11);
  os_tsk_create(slave_1_task, 12);
  os_tsk_create(slave_2_task, 13);
/* Main */
int main(void)
  os_sys_init(boot_task);
That a call will be _free_box is not clearing the message sent recently?
Message allocated by _alloc_box is automatically removed by os_mbx_wait?
