# include <stdio.h> # include <aduc842.h> #pragma registerbank(2) void sendmoduleinit(void); void InitByte_Char (volatile unsigned long); void print2uart_hex(int); void displaytemp1(void); void displaycal(void); void sendremaining(void); volatile unsigned char moduleinit; int ucRxChar1; int check_sum; int check_sum_tx; void main() { EA = 1; ES = 1; T3CON = 0x83; T3FD = 0x2D; SCON = 0x50; if(ucRxChar1 == 0xCC) { sendmoduleinit(); } if (ucRxChar1 == 0xFA && ucRxChar1 == 0xFA && ucRxChar1 == 0x05 && ucRxChar1 == 0xAA && ucRxChar1 == 0x2F) {displaytemp1(); } if (ucRxChar1 == 0x05 && ucRxChar1 == 0xAB) {displaycal(); } } void ISR_sc(void) interrupt 4 using 2 { if (TI==1) { TI=0; //clear interrupt } else { ucRxChar1 = SBUF; //put value on pins RI=0; //clear interrupt } /*REN = 1; while(RI == 0) {} ucRxChar1 = SBUF; RI = 0; */ } void sendmoduleinit(void) { check_sum = (0xF5 ^ 0xF5 ^ 0x06 ^ 0xFF ^ 0xFF); check_sum_tx = (check_sum & 0x7F); InitByte_Char(0xF5); InitByte_Char(0xF5); InitByte_Char(0x06); InitByte_Char(0xFF); InitByte_Char(0xFF); print2uart_hex(check_sum_tx); } void InitByte_Char (volatile unsigned long result) { REN = 0; SBUF = result; while (TI == 0) { } TI = 0; REN = 1; } void print2uart_hex(int chksum) { REN = 0; SBUF = chksum; while (TI == 0) { } TI = 0; REN = 1; } void displaytemp1(void) { check_sum =(0xA0 ^ 0xE2 ^ 0x07 ^ 0x00 ^ 0x62 ^ 0x00); check_sum_tx = (check_sum & 0x7F); InitByte_Char(0xA0); InitByte_Char(0xE2); InitByte_Char(0x07); InitByte_Char(0x00); sendremaining(); //InitByte_Char(0x62); // InitByte_Char(0x00); // print2uart_hex(check_sum_tx); } void sendremaining(void) { InitByte_Char(0x62); InitByte_Char(0x00); print2uart_hex(check_sum_tx); } void displaycal(void) { check_sum =(0xA0 ^ 0xE2 ^ 0x07 ^ 0x00 ^ 0x25 ^ 0x00); check_sum_tx = (check_sum & 0x7F); InitByte_Char(0xA0); InitByte_Char(0xE2); InitByte_Char(0x07); InitByte_Char(0x00); InitByte_Char(0x25); InitByte_Char(0x00); print2uart_hex(check_sum_tx); }
This is my code. Over here I am trying to read bytes into SBUF and depending upon bytes received I am trying to send some packets. My code is working but reading into SBUF is taking time... Reading a single byte is not taking time but reading an entire packet takes time can u suggest some alternative soln regards Mayuri
It's not the reading into SBUF that is taking time. It's the way your grabbing it and then checking for a specific sequence of characters.
You need to revisit this code and consider how characters are received by the processor.
Some better compilers would notice that above expression can never be true, and warn about unreachable code.
But there are lots of interesting things with this code - for example why it constantly turns on/off the UART receiver. Is RX and TX of the UART connected together, so you need to stop the UART from hearing its own transmission?
