hi to all
i had programed my lpc2132 by j-tag. but my IC hasn't any output!! i wrote a very simple flasher codes and now it doesn't respond me!!! j-tag says that programming is complete and i think i don't have hardware problems too. i don't know what to do pls help me!!! is there any work that i hadn't do that?????!!!!
How can we help, when you don't supply any information?
How do we know that your project configuration is correct, so you really build an application for the correct processor, and places that application at the correct address?
How do we know that your hardware performs a reset?
How do we know what your simple application does, so we may know if it erally should flash any LED or whatever you intend it to do?
Next thing: if you have JTAG support, I would have expected that you should also be able to debug. What is happening?
By the way - exactly how is LPC2132 a good description of your issue?
if i send my files(keil and proteuse files) can u help me?
if u see those files u can find out what i want to do and what is my problem!!!
how can i send files?
Why do you assume that I'm so bored that I would spend time looking through other peoples files?
What have _you_ done to try to figure out if you build a valid binary, and get it correctly downloaded, and get the processor to start to run the binary?
are u angry? i did that but i have the problem yet.
You did what, exactly?
And what did you discover in the process?
If I understand correctly you are trying to make a blinky application, have you tried the example supplied with uvision?
If your code is not too long you can post it here.
Are you using a dev board or a self made one?
Alex
