Dear All,
I'm programming an app that writes to SD card and I'm using the Keil FlashFS on STM32F100C8 device. In the documentation of Keil I found that the SPI driver have some functions in order to communicate with the card:
Init Initializes the SPI controller. UnInit Uninitializes the SPI controller. Send Send and receive a byte over the SPI interface. SendBuf Sends a block of data to the SPI interface. RecBuf Receives a block of data from the SPI interface. BusSpeed Set the desired baud rate speed for the SPI interface. SetSS Enables or disables SPI Slave Select signal. CheckMedia Checks the SD/MMC media status (Card Inserted, Write Protected).
This functions are defined in the FileConfig.h, but, in my FileConfig.h I only have some functions like spi_send, spi_command etc, but don't have SendBuf, RecBuf, etc.. for this reason my write speed is too slow because it don't have functions to send a buffer of data...
Also SDHC card are not supported and don't know why. My version of RL-ARM is 4.13, I think the newest... can anybody explain why cant found the rest of functions and the SDHC problem??
Thanks in advance.
I don't know what you are doing, but SDHC has been supported for over a year now - and I'm using 4.14. 4.13 should be no different.
