Below is the program for moving message on lcd.....ws not working on chip....if u can help me any modifications..it is for philips P89v51rd2fn lcd is jhd162a
#include<reg51.h> sfr lcd_data_pin=0x90; // port 1 sbit rs=P3^0; // Register select pin sbit rw=P3^1; // Read write pin sbit en=P3^2; // Enable pin
void delay(unsigned int msec) //delay function { int i,j; for(i=0;i<msec;i++) for(j=0;j<1275;j++); }
void lcd_cmd(unsigned char comm) // function to send command to LCD { lcd_data_pin=comm; en=1; rs=0; rw=0; delay(25); en=0; } void lcd_data(unsigned char disp) // function to send data on LCD { lcd_data_pin=disp; en=1; rs=1; rw=0; delay(25); en=0; }
void lcd_puts(unsigned char *s) // function to send string to LCD { while(*s!='\0') { lcd_data(*s); s++; } }
void lcd_ini() //Function to initialize the LCD { lcd_cmd(0x38); lcd_cmd(0x06); lcd_cmd(0x80); lcd_cmd(0x01); lcd_cmd(0x0C); } void main() { lcd_ini(); lcd_cmd(0x81); lcd_puts("HELLO"); delay(25); while(1) { lcd_cmd(0x1C); //Shift the entire display to right delay(50); } }
Without knowing the LCD controller comands, one could possibly think that maybe it is working... just too fast for you to see (or the slow LCD segments to have time to change state)
so looking at the last few lines: - display hello, - call delay routine for 25ms, - then the final loop shifts the display to right as fast as possible - read as very fast because the delay(50) is in the comments and not in code.
so to analyse: display hello, then after 25mS, shift it very rapidly off the screen. even if the LCD could display the 'HELLO' in 25mS (LCD's are pretty slow), your' eyes are not that fast.
As a seperate subject, it is bad form to create delays using software loops - use a hardware timer. Software loop timers will one day sooner or later come back to bite you in so many ways!
- Phil.
owk..but is rest program right? i have a doubt regarding the header file..can u tell me header file for phiilips p89v51rd2fn?
can u tell me
