How to receive character to P89V51RD using serial communication?
Hi everyone,
In my code receive session is not working.. what changes should i made to receive a character from my keyboard?
// Program to test serial communication of controller with PC using hyper terminal
#include<reg51.h>
void ini()     // Initialize Timer 1 for serial communication
TMOD=0x20;  //Timer1, mode 2, baud rate 9600 bps
TH1=0XFD;
SCON=0x50;
TR1=1;
void recieve()  //Function to receive serial data
unsigned char value;
while(RI==0);
value=SBUF;
P1=value;
RI=0;
void transmit()  // Funtion to transmit serial data
P2=P1-32;
SBUF=P2;
while(TI==0);
TI=0;
SBUF=P1;
while(TI==0);
TI=0;
void main()
while(1)
  ini();
  recieve();
  transmit();
Thank in advance
  • You have to study uart methods.
    This is the a simple one using polling.
    /*               Echo Back: test for uart @ 9600              */
    /*               Polled uart implementation                   */
    // Needs proper connection of RXpin and TXpin between PC D9M and connector of embedded device.
    // If PC as DTE(D9M) and embedded as DCE(D9F) then 2 - 2, 3 - 3, 5 - 5 (straight cable).
    // If PC as DTE(D9M) and embedded as DTE(D9M) then 2 - 3, 3 - 2, 5 - 5 (cross over cable).
    // A chip as MAX232A(or like) must be used for proper signaling on RS232 line.
    // Terminal on PC like Hyperterminal must be configured for 9600, 8bit, no parity, no handshake.
    // At 9600 bps it is needed about 1ms to send(or receive) a byte through uart.
    // Uses a standard 8051 header file.
    // P89V51RD2 has more options than 8051, so the proper header must be used to exploit those features.
    #include <reg51.h>
    void uart_init();                 // Initializes UART peripheral
    char uart_getc();                 // Polled method to Receive a byte(8bit)
    void uart_putc (char c);          // Polled method to Transmit a byte(8bit)
    void uart_puts(char *s);          // Typical puts for uart Transmit a null-terminated-string
    void uart_init()                  // Initializes UART peripheral
      TMOD = 0x20;                    // Timer1, mode 2
      TH1  = 0xFD;                    // 9600 bps 11059200 Clock, core(12cycle), uart(SMOD=0)
      TL1  = 0xFD;                    // First byte timing
      SCON = 0x52;                    // 0x52 : 0101 0010  Receive Enable, TI as 1 (set as ready)
      TR1  = 1;
    char uart_getc()                  // Polled method to Receive a byte(8bit)
      while (RI == 0)                 // Wait until a byte has been received
      RI = 0;                         // Acknowledge RI
      return SBUF;                    //
    void uart_putc (char c)           // Polled method to Transmit a byte(8bit)
      while (TI == 0)                 // TI as 0 indicates TX busy,
        ;                             //    if busy then wait for TX completion of the previous byte
      SBUF = c;                       // Does not wait for TX of current byte to complete,
                                      //    so gives time to caller for other actions
    void uart_puts(char *s)           // Typical puts for uart Transmit a string-null-terminated
      while (*s)                      // Check for null byte termination
        uart_putc(*s++);              //    and send each byte using uart
    void main ()
       char c;
       uart_init();                   // Init UART to desired settings
       uart_puts("Hello, echoback testing serial communication\n\r");
       while (1) {                   // This loop echoes back whatever is typed on PC Keyboard
         c = uart_getc();            //    get next byte from PC
         uart_putc(c);               //    and send it back as echo
Reply Children
