Hi everyone,
I'm testing the SD-Card example from Keil. The SD-Card is detected as Unformatted and when I answer YES to format it, the operation fails and it continuously asks me to format the SD-Card.
According to information I found about the same issue, I have already specified the IRAM2 area as follows: Start=0x7FD00000 , Size=0x2000 and I have located the file FS_ARM_L.lib to that memory space. However this doesn't solve the issue, I mean the formatting operation fails and it aks me to format the SD-Card again and again. Any suggestion to solve the issue ? Something else I can check or set ?
Thank you in advance. Best regards
What are your jumper settings? Please read the Abstract.txt in SD_File example.
