When I intsall the latest MDK it stalls while installing m_ts.l into C:\Keil\ARM\RV31\LIB\armlib
The file just keeps getting larger (>70GB) until my hard disk runs out of space.
I tried an update install (over an older version) and a fresh install to a new directory, but both fail the same way
I tried the Windows 7 option of installing in XP compatibility mode bit that fails the same way too.
Use the integrity check to verify the installation.
http://www.keil.com/forum/20984
Sounds like a corrupted download - so have you tried to download it again. Make sure you don't download with a caching program that "helps" you by deciding that it's the same binary so no new download needed...
Even I am facing the same issue. I have downloaded the MDK-ARM V4.53.exe from the Keil web site. However while installation it gives an error half way through of installation as below:
"Check sum is corrupted.The installation needs to be stopped" Tried to uninstall the previous version and reinstalled the new version. Still the same error persists.
Can someone from the Keil reply to the post.
I have the same issue. Fills my disk >100GB and fails. Looks like it's corrupting something because it takes a disk scan to reclaim the space.
Anyone know what's wrong?
