i am working on following project. & its showing me some errors... & i am unable to remove them... please help me out...
program:-
/*HEADER FILES*/ #include<reg51.h> #include<string.h>
/*LCD PIN CONNECTIONS*/ #define lcd P0 sbit rs=P0^1; sbit en=P0^3;
/*LCD FUNCTIONS DECLARATIONS*/ void init_lcd(void); void cmd_lcd(unsigned char); void data_lcd(unsigned char); void str_lcd(unsigned char *); void Delay_ms(unsigned int);
/*KEYPAD PIN CONNECTIONS*/ sbit row0=P2^3; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^0; sbit col0=P2^4; sbit col1=P2^2; sbit col2=P2^1;
/*MOTOR PIN CONNECTIONS*/ sbit M1=P1^0; sbit M2=P1^5;
/*BUZZER PIN CONNECTION*/ sbit BUZZER=P1^2;
/*VARIABLES DECLARATION*/ unsigned char i,j; unsigned char colval,rowval,pwdchange;
unsigned char pwd[15],temp[],str1[]="12345";
unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',}; /*PASSWORD FUNCTION DECLARATION*/ void password(void);
/*KEYPAD FUNCTION DECLARATION*/ unsigned char key(void);
/*MAIN FUNCTION*/ main() { unsigned char k=0; BUZZER=0; //BUZZER OFF M1=M2=0; //MOTOR OFF
init_lcd(); //LCD INITIALIZATION FUNCTION CALLING str_lcd("ENTER PASSWORD:"); //DISPLAY STRING ON LCD while(1) { cmd_lcd(0xc0); //2ND LINE DISPLAY password(); //PASSWORD FUNCTION CALLING if(pwdchange) { pwdchange=0; continue; } if(!strcmp(str1,pwd)) //COMPARING WITH 1ST PASSWORD { BUZZER=0; //BUZZER OFF cmd_lcd(0xc0); str_lcd("DOOR OPEN");
M1=0; //MOTOR RUNS IN FORWARD DIRECTION M2=1; Delay_ms(30); //30 MILLISECONDS DELAY cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; Delay_ms(1500);
cmd_lcd(0xc0); str_lcd("DOOR CLOSE");
M1=1; M2=0; Delay_ms(30); cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; k=0;
} else {
strcpy(temp,pwd); cmd_lcd(0x01); str_lcd("Confirm Password"); cmd_lcd(0xc0); password(); if(!strcmp(temp,pwd)) { strcpy(str1,temp); cmd_lcd(0x01); str_lcd("Password'Changed"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else {goto label;
} else { goto label; }
else { label:pwd[i++]=j; data_lcd('*'); }
pwd[i]='\0'; }
//its showing 4 syntax error near else...
/*HEADER FILES*/ #include<reg51.h> #include<string.h> /*LCD PIN CONNECTIONS*/ #define lcd P0 sbit rs=P0^1; sbit en=P0^3; /*LCD FUNCTIONS DECLARATIONS*/ void init_lcd(void); void cmd_lcd(unsigned char); void data_lcd(unsigned char); void str_lcd(unsigned char *); void Delay_ms(unsigned int); /*KEYPAD PIN CONNECTIONS*/ sbit row0=P2^3; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^0; sbit col0=P2^4; sbit col1=P2^2; sbit col2=P2^1; /*MOTOR PIN CONNECTIONS*/ sbit M1=P1^0; sbit M2=P1^5; /*BUZZER PIN CONNECTION*/ sbit BUZZER=P1^2; /*VARIABLES DECLARATION*/ unsigned char i,j; unsigned char colval,rowval,pwdchange; unsigned char pwd[15],temp[],str1[]="12345"; unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',}; /*PASSWORD FUNCTION DECLARATION*/ void password(void); /*KEYPAD FUNCTION DECLARATION*/ unsigned char key(void); /*MAIN FUNCTION*/ main() { unsigned char k=0; BUZZER=0; //BUZZER OFF M1=M2=0; //MOTOR OFF init_lcd(); //LCD INITIALIZATION FUNCTION CALLING str_lcd("ENTER PASSWORD:"); //DISPLAY STRING ON LCD while(1) { cmd_lcd(0xc0); //2ND LINE DISPLAY password(); //PASSWORD FUNCTION CALLING if(pwdchange) { pwdchange=0; continue; } if(!strcmp(str1,pwd)) //COMPARING WITH 1ST PASSWORD { BUZZER=0; //BUZZER OFF cmd_lcd(0xc0); str_lcd("DOOR OPEN"); M1=0; //MOTOR RUNS IN FORWARD DIRECTION M2=1; Delay_ms(30); //30 MILLISECONDS DELAY cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; Delay_ms(1500); cmd_lcd(0xc0); str_lcd("DOOR CLOSE"); M1=1; M2=0; Delay_ms(30); cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; k=0; } else { strcpy(temp,pwd); cmd_lcd(0x01); str_lcd("Confirm Password"); cmd_lcd(0xc0); password(); if(!strcmp(temp,pwd)) { strcpy(str1,temp); cmd_lcd(0x01); str_lcd("Password'Changed"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; return; } } else {goto label; } else { goto label; } else { label:pwd[i++]=j; data_lcd('*'); } pwd[i]='\0'; }
1) What was the reason you did not specifically mark the source code lines you got compilation errors from? Or did you expect every reader of this thread to create a new Keil uVision project (trying to figure out what settings that may be relevant) and compile the code?
2) Skip using goto. Try Google and note the common view on the use of goto as a method to structure a C/C++ program. There could potentially exist one situation where a goto could help structurally. That is to do the job of a multi-level break statement. But even then, it is very easy to rewrite the code to not need any goto. In short - a goto is a developers failure to structure the code properly.
3) You have managed a huge number of return in your code. That doesn't always help the readability. But it becomes even more interesting when you have code like:
if (xx) { ... return; } else { goto xx; }
Note that the "return" statement makes that "else" statement meaningless, since the logic is the same as:
if (xx) { ... return; } goto xx;
But then that "goto" suddenly don't happen in a way that makes it meaningful anymore, since the decision to do that goto can be pushed further down/later.
In the end, that kind of code can often be rewritten as:
if (xx) { do_something(); } else if (yy) { do_something_else(); } else if (zz) { do_something_yet_different(); } else { see_got_here_with_zero_goto_in_source(); }
Read comment from 1-Mar-2012 13:16 GMT.
It does not discuss nested if, but if with multiple else. There can not be two "else" to one "if".
With proper indentation, it should be instantly visible that every else have a "if" with same indentation abit higher up. If there instead is another "else", then you have stumbled, and the compiler will cry.
Programming languages are no different from normal languages. You have "if xx then yy else zz". Not "if xx then yy else zz else ww". Because this variant would not have any rule to separate either zz or ww that "else" can't be logically processed.
Proper indentation (many styles exists and are just a question of preference unless you work for a company with official guidlines) is not really optional. Everything written should follow the same indentation rules. Then you will quickly learn to see unbalanced code without even reading the text. There is a huge reason why all modern programming languages are designed to allow white space to be used to "shape" the text lines, letting the text lines create a graphical pattern that we can see without zooming in our concentration on the actual characters and keywords.
You have lack of time. How many hours did you spend on this issue yesterday? Or the day before? I'm pretty sure the teacher gave you all a reasonable amount of time for the project. But with a fixed deadline, it doesn't work to stop and wait for others to supply answers. That is just hours eating away towards that deadline. Real tasks requiers real hours spent before that deadline. Real hours builds real experience. And real experience is what you need to get through the courses. And what you need to be able to get someone to pay you if you have any intention of developing software professionally.
the bane of proper indentation is right there on your keyboard labelled 'tab'
use spaces!
any decent editor will have a button "convert tabs to spaces"
Then you need to speak to your teacher, and request extra time! He/she will, of course, expect you to give a very good reason for the extension...
"i tried a lot but then also i was uable to remove those errors"
Then, again, you need to speak to your teacher - that's the correct place to go when you're stuck with your homework!
Per Westermark
i agree!! i"ll try again...........:)
hi!! tell me exact syntax for if with multiple else.. with using goto... as u said i changed some sentences... but its giving me same errors...:((
please explain me with some example... you are my teacher now!!
I'd like to see how you do that too ;)
There are no syntax for if with multiple else. There can only be zero or one else statement for every if statement. As I already mentioned, it is a logical impossibility to know which of multiple else to use if there isn't an "if" statement with a logical expression that performs the select of which of the two alternatives to use.
In some situations, it is possible to use a "computed goto".
One implementation of that is the switch statement in C.
Another implementation (better suited for processor architectures that doesn't suffer huge costs from indirect memory accesses) is tables with function pointers.
But your code is not a situation for any computed goto. You do not have a "one-out-of-ten" problem. You have a sequential problem. Each action can potentially trig a following action.
If A fails, we are done. Else we do B. If B fails we are done, else we do C.
This is a trivial problem that can be seen as having a number of postit notes and move around them until you get the most "beautiful" structure.
Note that the outcome of nested if/else can change drastically depending on if you favour the "if" part or the "else" part. Is it the "if" part that represents a failure? Or the "else" part?
A slightly naughty method for multiple error exits is the abuse of a loop:
do { if (!do_a()) break; if (!do_b()) break; ... if (!do_z()) break; // wow - we managed everything. return good_result; } while (0); // ouch - something went bad do_error_recovery(); return bad_result;
But no - your problem is not a problem that should make use of the above code. Your teacher would probably give you a long speech if you try that route.
So why not just consider the following?
if (xx) { do_a(); } else if (yy) { do_b(); } else if (zz) { do_c(); }
By the way - several days later. Aren't your deadline up yet? This is not a tough problem. It's rather easy. And there are a number of acceptable solutions. But "break" and "goto" should not be needed or used for this problem.
now its showing me 5 errors... '(' expected instead '{' near 1st else if statement.. and remaining syntax errors are as it is... :( :( (
/*HEADER FILES*/ #include<reg51.h> #include<string.h> /*LCD PIN CONNECTIONS*/ #define lcd P0 sbit rs=P0^1; sbit en=P0^3; /*LCD FUNCTIONS DECLARATIONS*/ void init_lcd(void); void cmd_lcd(unsigned char); void data_lcd(unsigned char); void str_lcd(unsigned char *); void Delay_ms(unsigned int); /*KEYPAD PIN CONNECTIONS*/ sbit row0=P2^3; sbit row1=P2^5; sbit row2=P2^6; sbit row3=P2^0; sbit col0=P2^4; sbit col1=P2^2; sbit col2=P2^1; /*MOTOR PIN CONNECTIONS*/ sbit M1=P1^0; sbit M2=P1^5; /*BUZZER PIN CONNECTION*/ sbit BUZZER=P1^2; /*VARIABLES DECLARATION*/ unsigned char i,j; unsigned char colval,rowval,pwdchange; unsigned char pwd[15],temp[],str1[]="12345"; unsigned char keypad[4][3]={'1','2','3','4','5','6','7','8','9','*','0','#',}; /*PASSWORD FUNCTION DECLARATION*/ void password(void); /*KEYPAD FUNCTION DECLARATION*/ unsigned char key(void); /*MAIN FUNCTION*/ main() { unsigned char k=0; BUZZER=0; //BUZZER OFF M1=M2=0; //MOTOR OFF init_lcd(); //LCD INITIALIZATION FUNCTION CALLING str_lcd("ENTER PASSWORD:"); //DISPLAY STRING ON LCD while(1) { cmd_lcd(0xc0); //2ND LINE DISPLAY password(); //PASSWORD FUNCTION CALLING if(pwdchange) { pwdchange=0; continue; } if(!strcmp(str1,pwd)) //COMPARING WITH 1ST PASSWORD { BUZZER=0; //BUZZER OFF cmd_lcd(0xc0); str_lcd("DOOR OPEN"); M1=0; //MOTOR RUNS IN FORWARD DIRECTION M2=1; Delay_ms(30); //30 MILLISECONDS DELAY cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; Delay_ms(1500); cmd_lcd(0xc0); str_lcd("DOOR CLOSE"); M1=1; M2=0; Delay_ms(30); cmd_lcd(0xc0); str_lcd(" "); M1=0; //MOTOR OFF M2=0; k=0; } else { strcpy(temp,pwd); cmd_lcd(0x01); str_lcd("Confirm Password"); cmd_lcd(0xc0); password(); if(!strcmp(temp,pwd)) { strcpy(str1,temp); cmd_lcd(0x01); str_lcd("Password'Changed"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } else if { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } } else if { cmd_lcd(0x01); str_lcd("Password Error"); Delay_ms(1000); cmd_lcd(0x01); str_lcd("Enter Password"); cmd_lcd(0xc0); pwdchange=1; } } else if {goto label; } else if { goto label; } else { label:pwd[i++]=j; data_lcd('*'); } pwd[i]='\0'; }
You are having a laugh, aren't you?
You need to go back to absolute basics!
www.loirak.com/.../ctutor.php
Look at
3. Loops and Conditions
even better, get a C book e.g. Kochan "programming in ANSI C" and learn C on the PC. C51 is not a good learning platform.
The goto statements are still there.
But now you have "introduced" a new version of C syntax:
... } else if <= if what? { cmd_lcd(0x01); ... }
Have you ever seen any text book describing any if statement that doesn't have a conditional expression? Exactly what would an "if" statement do, if you don't give it a condition?
Absolutely!
You have basic 'C' syntax errors - you need to go back to your 'C' textbook, and your 'C' class notes, and study them carefully!!
More basic 'C' learning links here: blog.antronics.co.uk/.../
I would argue that knowing C syntax isn't the biggest issue here.
For someone wanting to figure out a way to utilize multiple "else"s following one "if", growing a functional brain is probably far more urgent.
