Unexpected return code from os_mbx_send
I am using : µVision V4.22.22.0 Toolchain: MDK-ARM Standard Version: 4.22a
This code is causing my problem:
                        U8 res = os_mbx_send (CB_XMIT_MAILBOX, packetInfo, 0xFFFF);
                        if(OS_R_OK != res)
                                printf("CB_XMIT_MAILBOX ret code: %x\n", res);
                                abort();
Documentation says the return code can be either; OS_R_TMO OR OS_R_OK. Very infrequently the return code is 0x78. Does anyone know what this return code means?
                        From rtl.h
                        OS_R_TMO        The timeout has expired.
                        OS_R_OK         The message has been put in the mailbox.
                        #define OS_R_TMO        0x01
                        #define OS_R_OK         0x00
