Hi All,
Am trying to interface GSM(UART0) and GPS(UIART1). I checked individually both modules are working perfectly by connecting to the both UARTs. When i connect to the both then my MUC unit is going to be hanged. if i swith off the GPS moduel then it is working correctly. Can any one pls help me to solve this.
You give 0 (as in ZERO) background information. You post no code (use the proper tags - but hell, you'll probably won't...). You don't tell us any real test results. How can anybody help you?
You do not post a small code showing the involved areas (use the proper tags - but hell, you'll probably won't...).
If 4711 lines of code are posted, I, for one, have no intention of looking at it.
