How Can i READ RTC Registers, As I am trying read RTC_HOUR
Hi ,
I am using the following code with LPC2378 as Target, As on debugging this code , I should be able to read RTC_HOUR,RTC_MIN register. But as it reaches printf (bold) code lines. I am not able to do so. I am first time using RTC. Please Suggest how to read RTC and throw its value on UART.
As per my observation , there should be something which should be able to bring print control to UART 1 again after RTC initialization. And some variable which save the RTC register at a particular time instance. And Its an RTC, it should continuously show the time increment.
Please Suggest.
Code for RTC implementation
#include <LPC23xx.H>
#include <stdio.h>
void Init_UART(void);
void Init_RTC(void);
int main (void)
{ /* -------------Main----------------------------*/
Init_UART(); /* ----- Initializing UART-------------*/
Init_RTC(); /* ----- Initializing RTC-------------*/
printf("\n Real Time Clock ");
printf("\n HOUR :%d",RTC_HOUR); printf("\n MIN :%d",RTC_MIN);
while(1) { /*-------------Infinite Loop-------*/ }
void Init_UART() {
/* UART 2 Enable */ PINSEL0 |= 0x40000000; /* Enable TxD1 in P0.15 */
PINSEL1 |= 0x00000001; /* Enable RxD1 in P0.16 */
U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
U1DLL = 78; /* 9600 Baud Rate @ 12.0 MHZ PCLK */
U1LCR = 0x03; /* DLAB = 0 */
printf("\n ***** UART Initialized ***** \n"); }
void Init_RTC(void) {
/*RTC Clock Intialization*/
PCONP = 0X00000200; /* RTC power enabled*/
RTC_PREINT = 0X0000016E; /* for Xtal @12MHZ */
RTC_PREFRAC = 0X0000001E;
RTC_CCR = 0X00000011;
RTC_ILR =0X1; /*clears the counter increment interrupt*/
RTC_HOUR=12;
RTC_MIN=45;
RTC_SEC=59;
RTC_DOM=21;
RTC_MONTH=12;
RTC_YEAR=2011;
Best Regards,
Vinay. Kumar
