I am trying to edit the HTTP Header to change the "Content-Disposition" to "Attachment" to force a "Save As" to Download a XML-File (cgx-File).
So far i just found the function: cgx_content_type:
www.keil.com/.../rlarm_cgx_content_type.htm
I have tried to edit this function like this:
U8 *cgx_content_type (void) { return( "Content-disposition: attachment; filename=fname.ext\r\n" ); }
This works for IE (maybe incorrectly) but doesn't work for Firefox. I think the reason is that this function can only edit the "Content-Type" and not the "content-Disposition".
The Answer Header watched in Firebug looks like this and has no entry for "Content-Disposition" instead overwrites the "Content-Type":
Server Keil-EWEB/2.1 Content-Type Content-disposition: attachment; filename=fname.ext Cache-Control no-cache Connection close
Normally it should be like this (example from greenbytes.de/.../):
Date Fri, 16 Dec 2011 08:37:15 GMT Server Apache/2.2.14 (Ubuntu) Cache-Control no-cache Content-Disposition attachment; filename="foo.html" Content-Type text/html; charset="ISO-8859-1" Content-Length 524 Proxy-Connection Keep-Alive Connection Keep-Alive Age 0
Is there another way to do directly edit the HTTP-Header?
Thanks in advance, Mathias
