Hi all,
I am using an NXP LPC2478 with a 16MB external ram that i use as a heap (malloc and free functions)
my intent is to produce code that i can load from SD and execute in the heap. so, i think :), i have to use Position Indipendent Code.
this code is able to call code in ROM (use of --symdefs to produce a linking file) this code must have at least one function that i can call from ROM (use of +FIRST) this code has RW and ZI data, so it needs a sort of initialization this code has to be loaded from SD and executed in the heap in a runtime known position
this is my scatter load file:
LR_ROM 0xA0000000 PI { ER_RO +0 { *.o (+RO +RW +ZI) } }
the problems are:
PROBLEM1 If i try to put my function as first...
LR_ROM 0xA0000000 PI { ER_RO +0 { *.o (LOADERFIRST, +First) *.o (+RO +RW +ZI) } }
...i receive this error from linker: Error: L6942E: Execution Region ER_RO contains multiple +FIRST, sections:
PROBLEM2 Linker create __main function and Region$$Table to initialize RW and ZI data how can i manage this functions in a PI world?
thank you.
EDIT:
Initialization of this code must leave heap and stack regions untouched...
