This is not a Keil specific question, but I was hoping that somebody would be able to clarify the following as I don't have a lot of experience with Cortex M0 chips (I have a LPC1114 at my disposal):
I understand that unlike Cortex M3s, a Cortex M0 always runs in privileged mode. Therefore,
__disable_irq() ;
always disables the interrupts.
What is then the purpose of the SVC instruction on a Cortex M0? It is supposed to switch the core to a privileged mode just like a ARM7's SWI instruction, but apparently it is not necessary...? If so, I also don't need to do anything special when jumping from a bootloader to the application (in terms of processor mode), right?
I guess one use of SVC is to trigger some functions, like OS stuff that is tied to the SVC handler. But from a functional point of view, it seems to be void on a Cortex M0.
Going back to the origins of ARM and the SWI, I always saw the point of it as being an entry point into an OS - And the disable of interrupts was a consequence rather than the reason.
Surely that argument still holds true. Many older processors had equivalents. Even the lowly Z80 had their RST instructions.
Have you got a copy of "The Definitive Guide to the ARM Cortex-M0"? That might give some extra insight.
I do have a copy, and it states that the processor runs in privileged mode - always. Chapter 18 (Using SVC) states that "the SVC is rarely used directly without the OS". I guess that answers my question. I read a lot lately and somehow I mixed up the requirement to disable interrupts from privileged mode of a Cortex M3 and a Cortex M0, where it is always allowed (I even created a tiny project to disable the systick interrupt). Thanks for your reply.
