thumb
I wrote a function which call another function through a pointer of function call.
When I trace the call, as soon as I reach the function the thumb bit is cleared, and of course the program no more run correctly.
When I call the same function directly the thumb bit is not cleared, of course.
What are the mechanism which could clear my thumb bit?
normal call
unsigned char *ip1;
fnEraseFlashSector(ip1 ,0);
special call
ulong ( *tempt_Fct )( ulong );
ulong tempData;
ulong tempData2;
tempData = ((ulong (*)(ulong,ulong))tempt_Fct)(tempData,tempData2);
I need to write generic function calls for RPC.
  • This:
    is very unhealthy code. You should never get into a situation where you have to cast function pointers like that. Technically, that's quite likely to cause undefined behaviour. Losing a thumb bit on the way might be the least of your worries.
    You've also left out the most crucial past of your "special call" example: how you initialize that function pointer. For all you've allowed us to know, there never was a thumb bit in there to get lost.
    It's up to you to make sure that the function pointer is properly initialized before you use it.
  • This:
