Hi, I am trying to run the secondary bootloader demo code using sd-card and flash file system. I picked up the demo code from here: www.nxp.com/.../LPC2000_Series_Secondary_Bootloader.zip In the folder Bootloader_SD. Since it is written for LPC2387, while i am using LPC2138. So, i replaced MMC driver funtions with SPI driver functions. I also changed the UART1 port to UART0 port for (in serial.c) LPC2138 for pc interface. On compiling, only 5 waarnings:
SD\BL_SD.c(279): warning: #167-D: argument of type "U32 *" is incompatible with parameter of type "unsigned long *" SD\BL_SD.c(353): warning: #167-D: argument of type "U32 *" is incompatible with parameter of type "unsigned long *" SD\BL_SD.c(366): warning: #177-D: variable "IAP_return" was declared but never referenced SD\BL_SD.c(554): warning: #167-D: argument of type "U32 *" is incompatible with parameter of type "unsigned long *" SD\BL_SD.c(364): warning: C3017W: sector_size may be used before being set
On running, i can see the menu on Hyper-terminal. I am also able to see the list of files present in the sd-card using DIR command. But when i issue command CMD>> PROG ZCODE.BIN(enter) (Zcode.bin is binary file present in sd-card) it says programing ZCODE.BIN at 0x10000.... and that's it. hangs there......... It does so also on erase command. i.e ERASE 10 20(enter) ...hangs.... Have i missed something. I think the IAP.c file is valid for whole LPC2000 family..
Regards, Salman
Fix the warnings!
Note that even if unsigned and unsigned long are both same size (32-bit) on many 32-bit compilers, they may still complain about them being different data types. And it may sometimes require unsigned long and sometimes unsigned long long to get a 64-bit number (if the compiler even supports 64-bit integers).
The difference between a 32-bit unsigned and a 32-bit unsigned long is important, since printf()/scanf() use different formatting strings for unsigned and unsigned long. So recompiling on a target where they are not the same size will result in failed calls to printf()/scanf().
<quote>Fix the warnings!</quote>
what???
he can fix most warnings so easy. just paint the code with typecasts.
but no nO NO
a good programmer must understand what the warnings indicate and make appropriate corrections. they could have a deeper underlying cause.
Always yo're freind.
Zeusti
"a good programmer must understand what the warnings indicate and make appropriate corrections. they could have a deeper underlying cause."
Very true.
A type-cast might be an appropriate correction in some cases - but, as you say, that needs to be found as the result of careful study & consideration of the code.
Ok i am trying to find out why is the warning SD\BL_SD.c(364): warning: C3017W: sector_size may be used before being set coming in the following function. One simple way is to initialize sector_size to 0, but that would be a blind solution. I can't find why is this warning.
static void cmd_prog (char *par) { char *fname, *entry, *next; FILE *fin; U32 app_addr, sector_index, sector_size , sector_size_sum, total, cnt; // warning here BOOL prog_done, new_sector; //U32 IAP_return[2]; // fname: BIN filename, only BIN file is supported now fname = get_entry (par, &next); // Image file name if (fname == NULL) { printf ("\nImage filename missing.\n"); return; } if (strcmp(fname+strlen(fname)-3, "BIN") != 0 && strcmp(fname+strlen(fname)-3, "bin") != 0) { printf("\nOnly BIN file is supported.\n"); return; } // program address entry = get_entry (next, &next); // Image entry point if (entry == NULL) app_addr = DEFAULT_PROG_ADDR; else app_addr = strtoul(entry); // app_addr should be a starting address of some sector, // it's better to verify here sector_index = getSectorIndex(app_addr); if (sector_index == INVALID_RESULT) { printf("\nInvalid application address!\n"); return; } if (sector_index <= bl_sector_endidx) { printf("\nApplication address overlapped with boot loader!\n"); return; } printf("\nProgramming %s to 0x%x...\n", fname, app_addr); fin = fopen (fname,"rb"); /* open the file for reading */ if (fin == NULL) { printf ("\nFile %s not found!\n",fname); return; } prog_done = 0; new_sector = 1; total = 0; sector_size_sum = 0; do { cnt = fread (&IAP_Buf, 1, IAP_BUF_SIZE, fin); if (cnt == 0) /* error of EOF */ { prog_done = 1; break; } else { if (new_sector) { if (IAP_PrepareErase(sector_index) != 0 ) { printf("\nFailed to prepare/erase sector %d.\n", sector_index); prog_done = 1; break; } #if 0 // prepre sector [sector_index] to erase if(IAP_PrepareSec(sector_index, sector_index) != IAP_STA_CMD_SUCCESS) { printf("\nFailed to prepare sector %d.\n", sector_index); prog_done = 1; break; } // erase sector [sector_index] IRQDisable(); if (IAP_EraseSec(sector_index, sector_index) != IAP_STA_CMD_SUCCESS) { printf("\nFailed to erase sector %d.\n", sector_index); prog_done = 1; break; } IRQEnable(); #endif sector_size = (getSectorSize(sector_index) << 10); sector_size_sum = 0; new_sector = 0; } if (IAP_Program(sector_index, app_addr) != 0) { printf("\nFailed to program at 0x%x.\n", app_addr); prog_done = 1; break; } #if 0 // program 1kb [app_addr] // prepre sector [sector_index] to write if(IAP_PrepareSec(sector_index, sector_index) != IAP_STA_CMD_SUCCESS) { printf("\nFailed to prepare sector %d.\n", sector_index); prog_done = 1; break; } IRQDisable(); if ((IAP_CopyRAMToFlash(app_addr, (U32)IAP_Buf, IAP_BUF_SIZE)) != IAP_STA_CMD_SUCCESS) { printf("\nFailed to program at 0x%x.\n", app_addr); prog_done = 1; break; } if (IAP_Compare(app_addr, (U32)IAP_Buf, IAP_BUF_SIZE, IAP_return) != IAP_STA_CMD_SUCCESS) { printf("\nVerify failed at 0x%x.\n", app_addr); prog_done = 1; break; } IRQEnable(); #endif app_addr += IAP_BUF_SIZE; total += cnt; sector_size_sum += IAP_BUF_SIZE; if (sector_size_sum == sector_size) { sector_index++; new_sector = 1; } } } while (prog_done==0); printf("\n%d bytes programmed.\n", total); fclose (fin); }
The compiler thinks that the if statement with sector_size could be executed before sector_size is assigned to. In reality it's not because of your new_sector flag so you could initialize sector_size to anything to make the compiler happy.
I'm pretty sure the compiler warnings aren't your problem. More likely something about programming while running out of flash or similar, although I assume the IAP routines take that into account.
Andrew
