I've been evaluating Keil MDK-ARM for a while have an STM3210C-EVAL board in my hands. It's similar to Keil's MCBSTM32C eval board.
As usual, I tried to understand how to blink a LED. I manipulated an example project and tried to blink LED4 which is blue and connected to PD4. No luck. It was not blinking. I spend couple of hours to find what's wrong, but couldn't find any clue. Debug was running well but LED was not blinking. Then today, I just tried to blink other LED's after running out of other ideas. And voila, just the orange LED (LED2, PD13) started to blink.
So what can cause this?
They are 4 simple LED's connected to ports with 4 simple resistors. But I just can blink only one. And I'm sure they are working physically, since they are blinking with the demo firmware.
Am I missing something mysterious?
Here is the code I'm using. (Manipulated version of $K/ARM/Boards/Keil/MCBSTM32C/Blinky project)
/******************************************************************************/ /* BLINKY.C: LED Flasher */ /******************************************************************************/ /* This file is part of the uVision/ARM development tools. */ /* Copyright (c) 2005-2009 Keil Software. All rights reserved. */ /* This software may only be used under the terms of a valid, current, */ /* end user licence from KEIL for a compatible version of KEIL software */ /* development tools. Nothing else gives you the right to use this software. */ /******************************************************************************/ #include <stm32f10x_cl.h> #define LED_NUM 8 /* Number of user LEDs */ const long led_mask[] = { 1<<7, 1<<13, 1<<3, 1<<4}; int main (void) { int AD_val, i; int num = -1; int dir = 1; SystemInit(); /* Setup GPIO for LEDs */ RCC->APB2ENR |= 1 << 5; /* Enable GPIOD clock */ GPIOD->CRH = 0x33333333; /* Configure the GPIO for LEDs */ /* Setup and initialize ADC converter */ RCC->APB2ENR |= 1 << 9; /* Enable ADC1 clock */ GPIOC->CRL &= 0xFFF0FFFF; /* Configure PC4 as ADC.14 input */ ADC1->SQR1 = 0x00000000; /* Regular channel 1 conversion */ ADC1->SQR2 = 0x00000000; /* Clear register */ ADC1->SQR3 = 14 << 0; /* SQ1 = channel 14 */ ADC1->SMPR1 = 5 << 12; /* Channel 14 sample time is 55.5 cyc */ ADC1->SMPR2 = 0x00000000; /* Clear register */ ADC1->CR1 = 1 << 8; /* Scan mode on */ ADC1->CR2 = (1 << 20) | /* Enable external trigger */ (7 << 17) | /* EXTSEL = SWSTART */ (1 << 1) | /* Continuous conversion */ (1 << 0) ; /* ADC enable */ ADC1->CR2 |= 1 << 3; /* Initialize calibration registers */ while (ADC1->CR2 & (1 << 3)); /* Wait for initialization to finish */ ADC1->CR2 |= 1 << 2; /* Start calibration */ while (ADC1->CR2 & (1 << 2)); /* Wait for calibration to finish */ ADC1->CR2 |= 1 << 22; /* Start first conversion */ for (;;) { /* Loop forever */ if (ADC1->SR & (1 << 1)) { /* If conversion has finished */ AD_val = ADC1->DR & 0x0FFF; /* Read AD converted value */ ADC1->CR2 |= 1 << 22; /* Start new conversion */ } /* Calculate 'num': 0, 1, ... , LED_NUM-1, LED_NUM-1, ... , 1, 0, 0, ... */ num += dir; if (num >= LED_NUM) { dir = -1; num = LED_NUM-1; } else if (num < 0) { dir = 1; num = 0; } GPIOD->BSRR = 1 << 13; /* Please change 13 with the numbers 7,3 and 4 to try other LED's */ for (i = 0; i < ((AD_val << 8) + 100000); i++); GPIOD->BSRR = 1 << (13+16); /* Please change 13 with the numbers 7,3 and 4 to try other LED's */ for (i = 0; i < ((AD_val << 8) + 100000); i++); } }
It seems that you have missed to configure the GPIOD->CRL register which configures PD0..7 (defined as inputs after reset).
@Andy, you're right, that was my first idea, but Keil provides just TCPnet and FlashFS examples for this board. I thought that this was the closest Blinky Project available.
@Robert, thanks for the heads up. I think you've found what I'm missing. I'll try it when I get home.
I mean @Andrew, sorry for that :)
