USB HID multiple packet problem
Trying to send an InReport > 64 bytes. Read all threads(thanks Tsuneo) but still not working. That is too say, I'm using SimpleHIDWrite as my tester, 64-byte packets work fine. If I run this code, sending a 65-byte In Report using 2-packets, I get from SimplHIDWrite "Get Report Error: CRC mismatch (17)". Any help much appreciated!
BOOL HID_GetReport (void)
// ReportID = SetupPacket.wValue.WB.L;
switch (SetupPacket.wValue.WB.H)
    case HID_REPORT_INPUT:
        //We've been asked to report, go get report and send 1st packet
        GetInReport();
        //memcpy(&EP0Buf[0],(u8*)&MyInReport[0],sizeof(MyInReport));
        //memcpy(&EP0Buf[0],(u8*)&MyInReport[0],64);
        break;
    case HID_REPORT_OUTPUT:
        return (FALSE);          // Not Supported
    case HID_REPORT_FEATURE:
        /* EP0Buf[] = ...; */
        /* break; */
        return (TRUE);
void GetInReport (void)
        // Check if PBINT is pressed
        if((IOPIN0 & PBINT) == 0)
        {       //just add some data for now
                MyInReport[0] = 0xC1;
                MyInReport[1] = 0xD1;
                MyInReport[63] = 0x63;
        else
                MyInReport[0] = 0xC0;
                MyInReport[1] = 0xD0;
        VICIntEnClr  |= 0x00400000;            // Disable USB Interrupt
        USB_WriteEP(0x81, &MyInReport[0], 64); //Send 1st packet, 64 bytes
        iNextInPacket = 1;                     //Set flag for EP1 ISR
        VICIntEnable |= 0x00400000;            // Enable USB Interrupt
void USB_EndPoint1 (DWORD event)
        switch (event)
                case USB_EVT_IN:
                    if(iNextInPacket)
                    {  //OK, more data, send second packet (1-byte, total of 65-byte report)
                          iNextInPacket = 0;
                          USB_WriteEP(0x81, &MyInReport[64], 1);
                    break;
