Hi there,
I am having a MCB1700 board with me. I want to display an bmp image on the display. For that I wish to save the pixel values as a vaiable (in an Array) and display it.
I would be much obliged if you can help me.
Thank you
There are a number of applications out there that can convert a binary file into an C array of unsigned char data for inclusion in a build. That is normally the most "standard" way to include larger binary data into a project.
There are generic converters that just convert the entire file content to a data array.
There are also converters that specifically interpret the content of a file into a suitable 'C' representation - eg, extracting the image data from a BMP file.
I think GIMP may be able to save an image as a 'C' data array...?
