1. I would like to use the JTAG Port to Debug the XE167FH with the KEIL ULINK2. 2. There is no general problem of debugging the XE167FH with or without OS when I use JTAG Port A without additional external Memory, which would be connected with the EBC. 3. There is no general problem of debugging the XE167FH with or without OS when I use JTAG Port B without additional external Memory, which would be connected with the EBC. 4. There is no way to debug the XE167FH when using external memory, because the needed JTAG-Pins are blocked by the EBC!
In this Datasheet: "?
Or is there any other way to debug the XE167FH when using the EBC?
Thanks a lot Markus Weber
