Hi everyone,
I have posted to this forum a couple months ago about using the enable_irq()/disable_irq() instruction intrinsics in RealView Compiler (ARMCC V4.0.0.728). In that occasion, I set up two software interrupts for calling such intrinsics, as they only have the intended effect when not in User Mode.
Just now, though, I realized that interrupts were not being disabled. I know for a fact that my SWI are set up appropriately, because they change the value of a flag I set up. Does anyone have any clue what could be happening? Documentation seems to be pretty clear about the fact that one enters supervisor mode during SWI, and that would be appropriate for enabling/disabling interrupts, but I must be missing something.
Relevant source code
void __SWI_8 (void) { __enable_irq(); __enable_fiq(); interrupts_enabled = 1; } void __SWI_9 (void) { __disable_irq(); __disable_fiq(); interrupts_enabled = 0; }
Relevant links
Instruction Intrinsics http://www.keil.com/support/man/docs/armcc/armcc_chdfgfab.htm
disable_irq() www.keil.com/.../armccref_CJAFBCBB.htm
enable_irq() www.keil.com/.../armccref_CJAEAEHA.htm
ARMCC: MODIFY IRQ FLAG TO ENABLE/DISABLE INTERRUPTS (RealView Compiler V3) http://www.keil.com/support/docs/3229.htm
Thanks in advance, -- George Andrew Brindeiro Robotron Automation and Technology
Can anyone help me figure out what is going on?
too long since i did this.
when you go into the swi, the processor switches to another dedicated CPSR. you changing irq and fiq change the CPSR of the swi.
when you leave swi the original cpsr gets restored. you disabling irq and fiq are only good in side the swi.
can be bad detail but consept is right.
always yo're freind.
Zeusti
ARM programmer and chef management engineer and desine consultant (retyred)
I tried doing the following:
void __SWI_8 (void) { //__enable_irq(); //__enable_fiq(); int temp; __asm { MRS temp, SPSR_cxsf // Get SPSR ORR temp, temp, #0xC0 // Set IRQ/FIQ flag to disable MSR SPSR_cxsf, temp // Set SPSR } interrupts_enabled = 1; } void __SWI_9 (void) { //__disable_irq(); //__disable_fiq(); int temp; __asm { MRS temp, SPSR_cxsf // Get SPSR BIC temp, temp, #0xC0 // Clear IRQ/FIQ flag to enable MSR SPSR_cxsf, temp // Set SPSR } interrupts_enabled = 0; }
This compiles, and I thought it would work, but obviously it doesn't...
I checked the output of the compiler, I don't see any reference (except for comments) to my asm code. Specifically, this is what I get:
__SWI_8 PROC ;;;49 ;;;50 void __SWI_8 (void) 000084 e59f1040 LDR r1,|L1.204| ;;;51 { ;;;52 //__enable_irq(); ;;;53 //__enable_fiq(); ;;;54 int temp; ;;;55 ;;;56 __asm ;;;57 { ;;;58 MRS temp, SPSR // Get SPSR ;;;59 ORR temp, temp, #0xC0 // Set IRQ/FIQ flag to disable ;;;60 MSR SPSR, temp // Set SPSR ;;;61 } ;;;62 ;;;63 interrupts_enabled = 1; 000088 e3a00001 MOV r0,#1 00008c e5c10000 STRB r0,[r1,#0] ; interrupts_enabled ;;;64 } 000090 e12fff1e BX lr ;;;65 ENDP __SWI_9 PROC ;;;66 void __SWI_9 (void) 000094 e59f1030 LDR r1,|L1.204| ;;;67 { ;;;68 //__disable_irq(); ;;;69 //__disable_fiq(); ;;;70 int temp; ;;;71 ;;;72 __asm ;;;73 { ;;;74 MRS temp, SPSR // Get SPSR ;;;75 BIC temp, temp, #0xC0 // Clear IRQ/FIQ flag to enable ;;;76 MSR SPSR, temp // Set SPSR ;;;77 } ;;;78 ;;;79 interrupts_enabled = 0; 000098 e3a00000 MOV r0,#0 00009c e5c10000 STRB r0,[r1,#0] ; interrupts_enabled ;;;80 } 0000a0 e12fff1e BX lr ;;;81 ENDP
Any tips on where I'm wrong? This should be relatively straightforward.
Thanks, -- George Andrew Brindeiro Robotron Automation and Technology
http://www.keil.com/support/man/docs/armcc/armcc_Chdgddcj.htm
Restrictions on inline assembly operations
Some low-level features that are available in the ARM assembler armasm, such as branching and writing to PC, are not supported.
Registers such as r0-r3, sp, lr, and the NZCV flags in the CPSR must be used with caution. If you use C or C++ expressions, these might be used as temporary registers and NZCV flags might be corrupted by the compiler when evaluating the expression. See Virtual registers.
The pc, lr, and sp registers cannot be explicitly read or modified using inline assembly code because there is no direct access to any physical registers. However, you can use the following intrinsics described in the Compiler Reference Guide to access these registers:
