enable_irq()/disable_irq() in ARMCC V4
Hi everyone,
I have posted to this forum a couple months ago about using the enable_irq()/disable_irq() instruction intrinsics in RealView Compiler (ARMCC V4.0.0.728). In that occasion, I set up two software interrupts for calling such intrinsics, as they only have the intended effect when not in User Mode.
Just now, though, I realized that interrupts were not being disabled. I know for a fact that my SWI are set up appropriately, because they change the value of a flag I set up. Does anyone have any clue what could be happening? Documentation seems to be pretty clear about the fact that one enters supervisor mode during SWI, and that would be appropriate for enabling/disabling interrupts, but I must be missing something.
Relevant source code
void __SWI_8 (void)
  __enable_irq();
  __enable_fiq();
  interrupts_enabled = 1;
void __SWI_9 (void)
  __disable_irq();
  __disable_fiq();
  interrupts_enabled = 0;
Relevant links
Instruction Intrinsics
http://www.keil.com/support/man/docs/armcc/armcc_chdfgfab.htm
disable_irq()
www.keil.com/.../armccref_CJAFBCBB.htm
enable_irq()
www.keil.com/.../armccref_CJAEAEHA.htm
ARMCC: MODIFY IRQ FLAG TO ENABLE/DISABLE INTERRUPTS (RealView Compiler V3)
http://www.keil.com/support/docs/3229.htm
Thanks in advance,
George Andrew Brindeiro
Robotron Automation and Technology
  • I tried doing the following:
    void __SWI_8 (void)
      //__enable_irq();
      //__enable_fiq();
      int temp;
       __asm
         MRS     temp, SPSR_cxsf        // Get SPSR
         ORR     temp, temp, #0xC0      // Set IRQ/FIQ flag to disable
         MSR     SPSR_cxsf, temp        // Set SPSR
    void __SWI_9 (void)
      //__disable_irq();
      //__disable_fiq();
      int temp;
      __asm
         BIC     temp, temp, #0xC0      // Clear IRQ/FIQ flag to enable
    This compiles, and I thought it would work, but obviously it doesn't...
    I checked the output of the compiler, I don't see any reference (except for comments) to my asm code. Specifically, this is what I get:
                      __SWI_8 PROC
    ;;;49
    ;;;50     void __SWI_8 (void)
    000084  e59f1040          LDR      r1,|L1.204|
    ;;;51     {
    ;;;52       //__enable_irq();
    ;;;53       //__enable_fiq();
    ;;;54       int temp;
    ;;;55
    ;;;56        __asm
    ;;;57       {
    ;;;58          MRS     temp, SPSR             // Get SPSR
    ;;;59          ORR     temp, temp, #0xC0      // Set IRQ/FIQ flag to disable
    ;;;60          MSR     SPSR, temp             // Set SPSR
    ;;;61       }
    ;;;62
    ;;;63       interrupts_enabled = 1;
    000088  e3a00001          MOV      r0,#1
    00008c  e5c10000          STRB     r0,[r1,#0]  ; interrupts_enabled
    ;;;64     }
    000090  e12fff1e          BX       lr
    ;;;65
                              ENDP
                      __SWI_9 PROC
    ;;;66     void __SWI_9 (void)
    000094  e59f1030          LDR      r1,|L1.204|
    ;;;67     {
    ;;;68       //__disable_irq();
    ;;;69       //__disable_fiq();
    ;;;70       int temp;
    ;;;71
    ;;;72       __asm
    ;;;73       {
    ;;;74          MRS     temp, SPSR             // Get SPSR
    ;;;75          BIC     temp, temp, #0xC0      // Clear IRQ/FIQ flag to enable
    ;;;76          MSR     SPSR, temp             // Set SPSR
    ;;;77       }
    ;;;78
    ;;;79       interrupts_enabled = 0;
    000098  e3a00000          MOV      r0,#0
    00009c  e5c10000          STRB     r0,[r1,#0]  ; interrupts_enabled
    ;;;80     }
    0000a0  e12fff1e          BX       lr
    ;;;81
                              ENDP
    Any tips on where I'm wrong? This should be relatively straightforward.
    Thanks,
    void __SWI_8 (void)
      //__enable_irq();
      //__enable_fiq();
      int temp;
       __asm
    void __SWI_9 (void)
      //__disable_irq();
      //__disable_fiq();
      int temp;
      __asm
                      __SWI_8 PROC
    ;;;49
    ;;;51     {
    ;;;54       int temp;
    ;;;55
    ;;;56        __asm
    ;;;57       {
    ;;;61       }
    ;;;62
    ;;;64     }
    ;;;65
                              ENDP
                      __SWI_9 PROC
    ;;;67     {
    ;;;70       int temp;
    ;;;71
    ;;;72       __asm
    ;;;73       {
    ;;;77       }
    ;;;78
    ;;;80     }
    ;;;81
                              ENDP
    Thanks,
  • http://www.keil.com/support/man/docs/armcc/armcc_Chdgddcj.htm
    Restrictions on inline assembly operations
    Some low-level features that are available in the ARM assembler armasm, such as branching and writing to PC, are not supported.
    Registers such as r0-r3, sp, lr, and the NZCV flags in the CPSR must be used with caution. If you use C or C++ expressions, these might be used as temporary registers and NZCV flags might be corrupted by the compiler when evaluating the expression. See Virtual registers.
    The pc, lr, and sp registers cannot be explicitly read or modified using inline assembly code because there is no direct access to any physical registers. However, you can use the following intrinsics described in the Compiler Reference Guide to access these registers:
