Debugging EFM Gecko, can not step through code
Hello!
I am new to debugging Gecko controllers from Energy Micro with the Keil IDE. I have used IAR a bit and have no problems there.
When I enter debug mode in Keil it all seems well, and I am able to execute code. The problem is that stepping in code, set breakpoints while in debug mode and e.g run to cursor line will not work.
I am still able to download code to flash, and it executes just fine.
My project settings is copied from one of their app notes.
Any thoughts on this?
Thank you very much in advance!
- Christian
