Hello everybody, I am a new entrant in 8051 programming. I am able to set bits in assembly language. But when I tried to set bits in c using Keil IDE, the bits are not getting set even after using bitset function as preprocessor. The bits are flickering when pressed any button. Otherwise they are stable. Please have a look on my coding for setting the P1 bits. Please tell me what is wrong in the coding below to set bits?
#include <reg51.h>
#define bitset(a,b) ((a)|=(1<<(b))) #define bitclear(a,b) ((a)&= (1<<(b)))
sbit LEDtest = P1^7; sbit PB0_0 = P0^0; sbit PB0_1 = P0^1; static char bdata ibase; sbit pb00 = ibase^0; sbit pb01 = ibase^1; sbit firstscandone = ibase^2; sbit testbit1=ibase^3;
void delay1(int counts) { int i, j; for(i=0; i<1000;i++) for(j=0; j<counts; j++); }
void init1(void) { delay1(20); P0=0xff; P1=0x00; P0=0x00; P1=0x00; ibase=0; //firstscandone=1; bitset(ibase,2); testbit1=1; }
void debounce(void) { int x, y; if(PB0_0==1) { for(x=0; x<20; x++); if(PB0_0==1) { pb00=1; } else pb00=0; }
if(PB0_1==1) { for(y=0; y<20; y++); if(PB0_1==1) { pb01=1; } else pb01=0; } }
void main(void) { if(firstscandone==0) init1(); bitset(ibase,2); debounce(); if (pb00==1) { bitset(P1,4); delay1(10); bitclear(P1,5); }
if(pb01==1) { bitset(P1,5); delay1(10); bitclear(P1,4); } if(firstscandone==1) bitset(P1,7); }
What "button" are you talking about?
He is talking about the buttons on his keypad that he is reading and debouncing.
