LPC2378 ISR Problem
Hello Everybody. I tried since days to make my program jumping to ISR. But i still stuck with this problem. I think i already did the right programm and the right start-up file after searching in Internet. At the moment i don't know anymore what to do.
I want that my program jumps to ISR, if a rising edge or a falling edge occurs on my capture port.
I could watch the timer counter and the timer interrupt flag in the debugger but it doesn't jump to ISR. The Flag of my I_BIT is 0 in the beginning.[CPSR = 0x6000005F].So IRQ is enable!! When i give a rising edge signal on my capture-ports, the CPSR Register still contains: CPSR = 0x6000005F.
Sorry for my bad english and Thank you for any helps :-) The Main Programm is in the next message.
My Start-Up:
/* Stack Sizes */
.set  UND_STACK_SIZE, 0x00000004                /* stack for "undefined instruction" interrupts is 4 bytes  */
.set  ABT_STACK_SIZE, 0x00000004                /* stack for "abort" interrupts is 4 bytes                  */
.set  FIQ_STACK_SIZE, 0x00000004                /* stack for "FIQ" interrupts  is 4 bytes                             */
.set  IRQ_STACK_SIZE, 0X00000004                /* stack for "IRQ" normal interrupts is 4 bytes                       */
.set  SVC_STACK_SIZE, 0x00000004                /* stack for "SVC" supervisor mode is 4 bytes                                 */
/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs (program status registers) */
.set  MODE_USR, 0x10                            /* Normal User Mode        */
.set  MODE_FIQ, 0x11                            /* FIQ Processing Fast Interrupts Mode                                          */
.set  MODE_IRQ, 0x12                            /* IRQ Processing Standard Interrupts Mode                                      */
.set  MODE_SVC, 0x13                            /* Supervisor Processing Software Interrupts Mode                       */
.set  MODE_ABT, 0x17                            /* Abort Processing memory Faults Mode                                          */
.set  MODE_UND, 0x1B                            /* Undefined Processing Undefined Instructions Mode             */
.set  MODE_SYS, 0x1F                            /* System Running Priviledged Operating System Tasks  Mode      */
.set  I_BIT, 0x80                               /* when I bit is set, IRQ is disabled (program status registers) */
.set  F_BIT, 0x40                               /* when F bit is set, FIQ is disabled (program status registers) */
.text
.arm
.global Reset_Handler
.global _startup
.func   _startup
_startup:
# Exception Vectors
_vectors:       ldr     PC, Reset_Addr
                ldr     PC, Undef_Addr
                ldr     PC, SWI_Addr
                ldr     PC, PAbt_Addr
                ldr     PC, DAbt_Addr
                nop                                                     /* Reserved Vector (holds Philips ISP checksum) */
                ldr     PC, [PC,#-0x120]        /* see page 71 of "Insiders Guide to the Philips ARM7-Based Microcontrollers" by Trevor Martin  */
                ldr     PC, FIQ_Addr
Reset_Addr:     .word   Reset_Handler           /* defined in this module below  */
Undef_Addr:     .word   UNDEF_Routine           /* defined in main.c  */
SWI_Addr:       .word   SWI_Routine                     /* defined in main.c  */
PAbt_Addr:      .word   UNDEF_Routine           /* defined in main.c  */
DAbt_Addr:      .word   UNDEF_Routine           /* defined in main.c  */
IRQ_Addr:       .word   IRQ_Routine                     /* defined in main.c  */
FIQ_Addr:       .word   FIQ_Routine                     /* defined in main.c  */
                .word   0                                       /* rounds the vectors and ISR addresses to 64 bytes total  */
# Reset Handler
Reset_Handler:
                                /* Setup a stack for each mode - note that this only sets up a usable stack
                                for User mode.   Also each mode is setup with interrupts initially disabled. */
                        ldr   r0, =_stack_end
                        msr   CPSR_c, #MODE_UND|I_BIT|F_BIT     /* Undefined Instruction Mode  */
                        mov   sp, r0
                        sub   r0, r0, #UND_STACK_SIZE
                        msr   CPSR_c, #MODE_ABT|I_BIT|F_BIT     /* Abort Mode */
                        mov   sp, r0
                        sub   r0, r0, #ABT_STACK_SIZE
                        msr   CPSR_c, #MODE_FIQ|I_BIT|F_BIT     /* FIQ Mode */
                        mov   sp, r0
                                sub   r0, r0, #FIQ_STACK_SIZE
                        msr   CPSR_c, #MODE_IRQ|I_BIT|F_BIT     /* IRQ Mode */
                        mov   sp, r0
                        sub   r0, r0, #IRQ_STACK_SIZE
                        msr   CPSR_c, #MODE_SVC|I_BIT|F_BIT     /* Supervisor Mode */
                        mov   sp, r0
                        sub   r0, r0, #SVC_STACK_SIZE
                        msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT     /* User Mode */
                        mov   sp, r0
                                /* copy .data section (Copy from ROM to RAM) */
                ldr     R1, =_etext
                ldr     R2, =_data
                ldr     R3, =_edata
1:                      cmp     R2, R3
                ldrlo   R0, [R1], #4
                strlo   R0, [R2], #4
                blo     1b
                                /* Clear .bss section (Zero init)  */
                mov     R0, #0
                ldr     R1, =_bss_start
                ldr     R2, =_bss_end
2:                              cmp     R1, R2
                strlo   R0, [R1], #4
                blo     2b
                                /* Enter the C code  */
                b       main
.endfunc
.end
