I am working on ARM 9 s3c2440 processor in mini2440 friendly board. for coding i am using keil MDK software. my code is
//#include<s3c44B0X.h> #include <S3C2440.H> #include<stdio.h> #define MCLK 50000000 #define BAUD_RATE 115200 #define BAUD_RATE_DIVISOR (int)((MCLK/(16*BAUD_RATE))-1) #define TXD0READY (1<<2) char data,flag=0,c = 'Y'; void serialport_init(void) { ULCON0 = 0x0003; // 8bits,1 stopbit, no parity UCON0 = 0x0005; //Rx or Tx Interrupt Polling mode UFCON0 = 0x00; // FIFO is not Enabled UMCON0 = 0x00; UBRDIV0= BAUD_RATE_DIVISOR; } void delay(int a) { for(;a!=0;a--) { } } static void __irq UART0_RX_INT(void) { pISR_UART0= (unsigned int)UART0_RX_INT; INTSUBMSK = 0xFFFFFFFF; //MASK ALL THE INTERRUPTS SUBSRCPND = 0x01; //Enable Recevie interrupt SRCPND = 0x10000000; //Enable UART0 interrupt INTPND = 0x10000000; c = URXH0; flag = 1; INTMSK &= ~(BIT_UART0); /* Enable UART0 interrupt */ } void uart_interrupt_init(void) { int i=0; INTMOD = 0x0; //All=IRQ mode INTMSK = BIT_ALLMSK; //All interrupt is masked. INTSUBMSK = BIT_SUB_ALLMSK; //All sub-interrupt is masked. <- April 01, 2002 SOP pISR_UART0= (unsigned int)UART0_RX_INT; SUBSRCPND = 0x1; SRCPND = (1<<28); //Enable UART0 interrupt INTPND = (1<<28); INTSUBMSK = 0xFFFFFFFE; // Enabling only RX input INTMSK &= ~(BIT_UART0); /* Enable UART0 interrupt */ pISR_UART0 = (unsigned int) UART0_RX_INT; } int main(void) { int i = 10; GPBCON = 0x015400; GPBUP = 0x7ff; serialport_init(); uart_interrupt_init(); while(1) { // transmitting a single character continuous for testing while (!(UTRSTAT0 & TXD0READY)); UTXH0 = c; // if a char is received via interrupt then blink the leds for certain time. if(flag == 1) { while(i ) GPBDAT = 0x0FFFFFFFF; delay(9000000); GPBDAT = 0x000000000; } else { GPBDAT = 0x0FFFFFFFFF; } } }
but i am getting Dummy_isr error, interrupt number: 28, INTMSK = 0xefff ffff i tried a lot but i am unable to solve this . plz help to come out of this, plz plz plz if possible provide the source code
