Dummy_isr error, interrupt number: 28, INTMSK = 0xefff ffff
I am working on ARM 9 s3c2440 processor in mini2440 friendly board.
for coding i am using keil MDK software.
my code is
//#include<s3c44B0X.h>
#include <S3C2440.H>
#include<stdio.h>
#define MCLK 50000000
#define BAUD_RATE 115200
#define BAUD_RATE_DIVISOR (int)((MCLK/(16*BAUD_RATE))-1)
#define TXD0READY   (1<<2)
char data,flag=0,c = 'Y';
void serialport_init(void)
ULCON0 = 0x0003;         // 8bits,1 stopbit, no parity
UCON0  = 0x0005;         //Rx or Tx Interrupt Polling mode
UFCON0 = 0x00;           // FIFO is not Enabled
UMCON0 = 0x00;
UBRDIV0= BAUD_RATE_DIVISOR;
void delay(int a)
        for(;a!=0;a--)
static void __irq UART0_RX_INT(void)
pISR_UART0= (unsigned int)UART0_RX_INT;
INTSUBMSK = 0xFFFFFFFF;  //MASK ALL THE INTERRUPTS
SUBSRCPND = 0x01;               //Enable Recevie interrupt
SRCPND = 0x10000000;  //Enable UART0 interrupt
INTPND = 0x10000000;
c = URXH0;
flag = 1;
INTMSK   &= ~(BIT_UART0);            /* Enable UART0 interrupt           */
void uart_interrupt_init(void)
int i=0;
        INTMOD     = 0x0;                                        //All=IRQ mode
    INTMSK     = BIT_ALLMSK;                      //All interrupt is masked.
    INTSUBMSK  = BIT_SUB_ALLMSK;                  //All sub-interrupt is masked. <- April 01, 2002 SOP
        SUBSRCPND = 0x1;
        SRCPND = (1<<28);  //Enable UART0 interrupt
        INTPND = (1<<28);
        INTSUBMSK = 0xFFFFFFFE;  // Enabling only RX input
        pISR_UART0 = (unsigned int) UART0_RX_INT;
int main(void)
int i = 10;
        GPBCON = 0x015400;
    GPBUP  = 0x7ff;
        serialport_init();
        uart_interrupt_init();
        while(1)
                // transmitting a single character continuous for testing
                 while (!(UTRSTAT0 & TXD0READY));
                 UTXH0 = c;
        // if a char is received via interrupt then blink the leds for certain time.
                 if(flag == 1)
                        while(i )
                        GPBDAT = 0x0FFFFFFFF;
                        delay(9000000);
                        GPBDAT = 0x000000000;
                 else
                        GPBDAT = 0x0FFFFFFFFF;
but i am getting Dummy_isr error, interrupt number: 28, INTMSK = 0xefff
ffff
i tried a lot but i am unable to solve this .
plz help to come out of this, plz plz plz
if possible provide the source code
  • What is a "mini2440 friendly board" ?
    "i tried a lot"
    What, exactly, did you try?
    In particular, what preparation did you make before starting this project:
    Have you familiarised yourself with the ARM9 architecture?
    Have you familiarised yourself with the specific ARM9 chip?
    Have you familiarised yourself with the Keil tools?
    Have you familiarised yourself with the "mini2440 friendly board"?
    Have you spent time studying any tutorials, examples, etc for any of this?
    "i tried a lot"
