Dummy_isr error, interrupt number: 28, INTMSK = 0xefff ffff
I am working on ARM 9 s3c2440 processor in mini2440 friendly board.
for coding i am using keil MDK software.
my code is
//#include<s3c44B0X.h>
#include <S3C2440.H>
#include<stdio.h>
#define MCLK 50000000
#define BAUD_RATE 115200
#define BAUD_RATE_DIVISOR (int)((MCLK/(16*BAUD_RATE))-1)
#define TXD0READY   (1<<2)
char data,flag=0,c = 'Y';
void serialport_init(void)
ULCON0 = 0x0003;         // 8bits,1 stopbit, no parity
UCON0  = 0x0005;         //Rx or Tx Interrupt Polling mode
UFCON0 = 0x00;           // FIFO is not Enabled
UMCON0 = 0x00;
UBRDIV0= BAUD_RATE_DIVISOR;
void delay(int a)
        for(;a!=0;a--)
static void __irq UART0_RX_INT(void)
pISR_UART0= (unsigned int)UART0_RX_INT;
INTSUBMSK = 0xFFFFFFFF;  //MASK ALL THE INTERRUPTS
SUBSRCPND = 0x01;               //Enable Recevie interrupt
SRCPND = 0x10000000;  //Enable UART0 interrupt
INTPND = 0x10000000;
c = URXH0;
flag = 1;
INTMSK   &= ~(BIT_UART0);            /* Enable UART0 interrupt           */
void uart_interrupt_init(void)
int i=0;
        INTMOD     = 0x0;                                        //All=IRQ mode
    INTMSK     = BIT_ALLMSK;                      //All interrupt is masked.
    INTSUBMSK  = BIT_SUB_ALLMSK;                  //All sub-interrupt is masked. <- April 01, 2002 SOP
        SUBSRCPND = 0x1;
        SRCPND = (1<<28);  //Enable UART0 interrupt
        INTPND = (1<<28);
        INTSUBMSK = 0xFFFFFFFE;  // Enabling only RX input
        pISR_UART0 = (unsigned int) UART0_RX_INT;
int main(void)
int i = 10;
        GPBCON = 0x015400;
    GPBUP  = 0x7ff;
        serialport_init();
        uart_interrupt_init();
        while(1)
                // transmitting a single character continuous for testing
                 while (!(UTRSTAT0 & TXD0READY));
                 UTXH0 = c;
        // if a char is received via interrupt then blink the leds for certain time.
                 if(flag == 1)
                        while(i )
                        GPBDAT = 0x0FFFFFFFF;
                        delay(9000000);
                        GPBDAT = 0x000000000;
                 else
                        GPBDAT = 0x0FFFFFFFFF;
but i am getting Dummy_isr error, interrupt number: 28, INTMSK = 0xefff
ffff
i tried a lot but i am unable to solve this .
plz help to come out of this, plz plz plz
if possible provide the source code
