Hello I have interfaced EFSL(SD Card) with LPC1768 and its working fine. But I am not able to check the number of bmp files in current dir.
ls_openDir(&list ,&(efs.myFs ),"/"); while(ls_getNext(&list)==0)
The above code is for open the dir and get next file list. Please give some thoughts on how to get num of bmp files in current dir.
The EFSL code is at Downloads section of coineltech.com/.../33 "LPC1768 HPLUS Saple Code".
Actually, that's just someone redistributing it.
The EFSL home page is: http://efsl.be/
Which points you to: sourceforge.net/.../
Where there is a support page: sourceforge.net/.../support
As Tamir says, it has nothing to do with Keil!
"it has nothing to do with Keil!"
it may not have anything to do with keil: the problem could be compiler related. we don't know for sure, at this point.
"we don't know for sure, at this point."
What information do you feel you are missing?
The OP did write: "Please give some thoughts on how to get num of bmp files in current dir."
