double trouble?
Hi all.
using uVision 4, keil compiler.
I'm trying to create a very simple function that takes an argument list, but it seems like when i use parameters of type double, it doesn't work right. I started fiddling around with the double datatype, and maybe i'm doing something wrong, but ...
// double trouble
double d = 1234.1234;
double* dp = &d;
double e = *dp;
// e has gibberish, d is fine
// float is ok
float f = 1234.1234;
float* fp = &d;
float g = *fp;
// g is fine, f is fine
// in fact ...
float* fp = &d;
double g = *fp;
// g has gibberish, f is fine
// also ...
double d = (double)f;
// d has gibberish(!)
// wha...
double e = d;
// both d and e have gibberish.
// contrast to
float d = 1234.1234;
float e = d;
// both d and e are fine
// adding a pointer.. cures it?
double* dp = &d;
double e = d;
// e has gibberish, d is fine.
// more pointers...
double* dp = &d;
double e = d;
double* ep = &e;
// both d and e are fine.
can someone explain what's going on???
