Debugging fopen in FlashFS
Hello all.
We're using a board based on a STM32f217zg with the RL-ARM libraries and currently we're trying to get a file system working on the micro SD card using SPI (SPI3 to be exact). We've gotten similar code working on a MCBSTM32C (STM32f107) board and could read and write files/directories etc with great success.
After modifying the code to work on the 217, we could successfully call finit(), and also fformat("m:"), and it behaves as expected.
however, we are unable to create files using the fopen command, which returns a NULL file pointer. Nor are we able to open existing files using the same command.
My question is: are there any ways to go about debugging this? there doesn't seem to be any error codes to be obtained from the Keil libraries... Am I forced to debug this on the SPI level, looking at the commands being sent back and forth?
Thanks for any advice.
