I have been using a Stellaris LM3S1968 eval board for a while now and all of a sudden I load a project that I have programmed it with several times and I get "Can't access memory". The project is the very simple graphic display routine that is supplied with the Stellarisware 7243 package. ULINK2 connection to uV3.24. The previous suggestion that the error message is due to "memory not implemented" does not seem to address the issue as raised by an earlier post.
It seems that there must be an electrical fault somewhere but I can't find any so far. Any insight would be appreciated.
Mike Mosley
