Hi everyone,
Is it possible for armlink to handle a 'root region' from a library (not an object file)? I've tried to do that via a scatter loading file, but did not succeed.
> armlink --noremove --callgraph --map --info totals,unused --symbols --list myprog.map --scatter scatter.txt --entry entrypoint -o myprog.axf myprog.o mylib.a "scatter.txt", line 9 (column 12): Error: L6236E: No section matches selector - no section to be FIRST/LAST.
However, 'entrypoint' is part of INITCA9 section, contained in mylib.a.
> fromelf mylib.a | grep INITCA9 ** Section #1 'INITCA9' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR + SHF_ENTRYSECT]
Scatter.txt looks like this:
ROM_LOAD 0x80000000 { ROM_EXEC +0 { * (INITCA9, +First) ; Core initialization code [...]
Note that linking works without complaints from armlink whenever I add the object file directly to the command line:
> armlink --noremove --callgraph --map --info totals,unused --symbols --list myprog.map --scatter scatter.txt --entry entrypoint -o myprog.axf myprog.o mylib.a init.o
Thanks for your help in advance!
Ciao, Andre
Not sure if it's case sensitive but have you tried +FIRST? That's what I've seen in the newer manuals.
