Software usart with assembler
Hi all.
I got a code from a site, www.8051projects.net/.../software-uart-8051.php
The code is assembler, and i want to put on my keil C code, my MCU is at89c51ed2 running at 11.0592MHZ.
after put assembler code on my project, balow MY source code
#include <regx51.h>
#include <stdio.h>
void putc(unsigned char);
#pragma ASM
?SU?PUTC SEGMENT CODE
?SU?GETC SEGMENT CODE
PUBLIC _putc
PUBLIC getc
txd_pin EQU     P2.1            ;Transmit on this pin
rxd_pin EQU     P2.0            ;Receive on this pin
;Formula to calculate the bit time delay constant
 ;This constant is calculated as: (((crystal/baud)/12) - 5) / 2
 ;crystal is the frequency of crystal in Hz
 ;baud is required baudrate
 ;Please try to keep baudrate below 9600
 ;to get best results :)
BITTIM  EQU     45;             (((11059200/9600)/12) - 5) / 2
 ;To send data serially
 ;For C programs
 ;Protype definition:
 ;               void putc(unsigned char);
 ;Usage:
 ;               putc(data);
 ;Return:
 ;               This function returns nothing
 ;For Assembly Programs:
 ;Usage:
 ;       data to be send has to be moved to R7
 ;       for example:
 ;               mov R7,#'a'
 ;               lcall _putc
 RSEG ?SU?PUTC
 _putc:
         push ACC
         Push PSW
         mov a,r7
         CLR txd_pin                     ;Drop line for start bit
         MOV R0,#BITTIM          ;Wait full bit-time
         DJNZ R0,$                       ;For START bit
         MOV R1,#8                       ;Send 8 bits
 putc1:
         RRC A                           ;Move next bit into carry
         MOV txd_pin,C           ;Write next bit
         DJNZ R0,$                       ;For DATA bit
         DJNZ R1,putc1           ;write 8 bits
         SETB txd_pin            ;Set line high
         RRC A                           ;Restore ACC contents
         DJNZ R0,$                       ;For STOP bit
         POP PSW
         pop ACC
         RET
 ;To receive data Serially
 ;If you want to use this routine in your
 ;C program then define function prototype
 ; as:
 ;       unsigned char getc(void);
 ;       Usage:
 ;               data = getc();
 ;       Return value:
 ;               Returns data received
 ;If you are using it in assembly program
 ;       Usage:
 ;               lcall getc
 ;       Return:
 ;               data received is stored in R7
RSEG ?SU?GETC
 getc:
         Push ACC
         Push PSW
         JB rxd_pin,$            ;Wait for start bit
         MOV R0,#BITTIM/2        ;Wait 1/2 bit-time
         DJNZ R0,$                       ;To sample in middle
         JB rxd_pin,getc         ;Insure valid
         MOV R1,#8                       ;Read 8 bits
 getc1:
         MOV C,rxd_pin           ;Read bit
         RRC A                           ;Shift it into ACC
         DJNZ R1,getc1           ;read 8 bits
         mov r7,a
         POP PSW
         pop ACC
         RET                                     ;go home
#pragma ENDASM
void main(void)
while(1){
  putc('A');
  //P0 = !P1;
The loop cals putc to print 'A', but nothing goes out on port P2.1
I´m calling the assembler wrong? or wrong mode?
I really need a software usart, i tryed all code avaible on the net, but seens nothing work.
If somebody have software usart running at 9600bps it is very importanto for me, if you have the C code it is very helpful.
Thanks a lot and... of course, sorry my bad english
