P89v51rd2 spi not working-help
I am trying to interface ADC-cs5463 with P89v51rd2 micro controller using "bit banging SPI" code but not getting any result.
I am using below code if any one can see the code and if i am making some mistake or doing wrong than reply me.
Please help me to find the problem.
#include "p89v51rx2.h"
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
//-----------------------------------ADC CS5463------------------
sbit nreset = P3^3; //RESET PIN OF CS5463
sbit cs = P3^4; //CHIP SELECT OF CS5463
sbit sclk = P3^7; //SERIAL CLOCK
sbit sdo = P3^6; //SERIAL DATA OUT
sbit sdi = P3^5; //SERIAL DATA IN
unsigned char sec_cnt=0;
unsigned long longVar=0;
unsigned char mdatahigh;
unsigned char mdatamid;
unsigned char mdatalow;
//--------------------- Functions Related to CS5463 ---------------------------------
void init_cs5463(void);
void main(void)
init_cs5463();//initiallises the cs to function as per our requirements
write_to_reg(0x40,PCB,0x80,0x61); //write to config register(0x40)
cs=0;
transfer_byte(0xe8); // start continuous conversions..
cs=1;
//Here is my while loop and try to read the CS5463 register and disply it,but not able //to get any response from the it.
longVar = 0;
while(1)
read_a_reg(0x40,(unsigned char *)&longVar);
float2str(longVar,&disp_buffer[4],0);
float2str(mdatahigh,&disp_buffer[16],0);
float2str(mdatamid,&disp_buffer[19],0);
float2str(mdatalow,&disp_buffer[22],0);
void transfer_byte(unsigned char datum)
unsigned char count,tempbyte;
sclk=0;
tempbyte=0x80;
for(count=0;count<8;count++) {
if(datum & tempbyte) {
sdi=1;
else {
sdi=0;
sclk=1;
sclk=0;
tempbyte=tempbyte>>1;
sdi=1;
delay(10);
unsigned char receive_byte(void)
unsigned char count,tempbyte,datal;
sdi=1;
datal=0x80;
tempbyte=0;
sdo=1;
if(sdo) {
tempbyte|=datal;
} sclk=1;
sclk=0;
datal=datal>>1;
return(tempbyte);
void read_a_reg(unsigned char command,unsigned char * ptr)
cs=0;
transfer_byte(command);
mdatahigh=receive_byte();
mdatamid=receive_byte();
mdatalow=receive_byte();
cs=1;
*ptr=mdatalow;
ptr++;
*ptr=mdatamid;
ptr++;
*ptr=mdatahigh;
void write_to_reg(unsigned char command,unsigned char high,unsigned char mid,unsigned char low)
cs=0;
transfer_byte(high);
transfer_byte(mid);
transfer_byte(low);
cs=1;
