This is the example code i used for the simulation in keil.
after runs the simulation, the status reg changes to 0x08, but not entering to interrupt service routine.
#include <LPC21xx.H> unsigned char I2CAddress; unsigned char I2CData; void I2CISR (void) // I2C interrupt routine { switch (I2STAT) // Read result code and switch to next action { case ( 0x08): // Start bit I2CONCLR = 0x28; // Clear start bit I2DAT = I2CAddress; // Send address and // write bit break; case (0x18): // Slave address+W, ACK I2DAT = I2CData; // Write data to tx register break; case (0x20): // Slave address +W, Not ACK I2DAT = I2CAddress; // Resend address and write bit break; case (0x28): // Data sent, Ack I2CONSET = 0x10; // Stop condition break; default : break; } I2CONCLR = 0x08; // Clear I2C interrupt flag VICVectAddr = 0x00000000; // Clear interrupt in } void init() { VICVectCntl1 = 0x00000029; // select a priority slot for a given interrupt VICVectAddr1 = (unsigned)I2CISR; VICIntEnable = 0x00000200; PINSEL0 = 0x50; I2SCLH = 0x08; I2SCLL = 0x08; } void I2CTransferByte(unsigned Addr,unsigned Data) { I2CAddress = Addr; // Place address and data in Globals to be used by // the interrupt I2CData = Data; I2CONCLR = 0xFF; // Clear all I2C settings I2CONSET = 0x40; // Enable the I2C interface I2CONSET = 0x20; // Start condition } void main() { init(); I2CTransferByte(0x81,0x90); while(1); }
The below code is NXP example.
still HAVE THAT PROBLEM
#include"LPC210x.h" void Initialize(void); /* I2C ISR */ __irq void I2C_ISR(void); /* Master Transmitter states */ void ISR_8(void); void ISR_18(void); void ISR_28(void); /*************************** MAIN ************************/ int main() { /* Initialize system */ Initialize (); /* Send start bit */ I2CONSET=0x60; /* Do forever */ while(1) { IOCLR=0x40; IOSET=0x40; } } /*************** System Initialization ***************/ void Initialize() { IODIR=0xF0; IOSET=0xF0; /*initializing I2C */ PINSEL0 = 0x50; I2CONCLR = 0x6c; I2CONSET = 0x40; I2SCLH = 0x08; I2SCLL = 0x07; /* Initialize VIC for I2C use */ VICIntSelect=0x0; /* selecting IRQ */ VICIntEnable= 0x200; /* enabling I2C */ VICVectCntl0= 0x29; /* highest priority and enabled */ VICVectAddr0=(unsigned long) I2C_ISR; /* ISR address written to the respective address register*/ } __irq void I2C_ISR() { int temp=0; temp=I2STAT; switch(temp) { case 8: ISR_8(); break; case 24: ISR_18(); break; case 40: ISR_28(); break; default : break; } VICVectAddr=0xFF; } /* I2C states*/ /* Start condition transmitted */ void ISR_8() { /* Port Indicator */ IOCLR=0x10; /* Slave address + write */ I2DAT=0x74; /* Clear SI and Start flag */ I2CONCLR=0x28; /* Port Indicator */ IOSET=0x10; } /* Acknowledgement received from slave for slave address */ void ISR_18() { /* Port Indicator */ IOCLR=0x20; /* Data to be transmitted */ I2DAT=0x55; /* clear SI */ I2CONCLR=0x8; /* Port Indicator */ IOSET=0x20; } /* Acknowledgement received from slave for byte transmitted from master. Stop condition is transmitted in this state signaling the end of transmission */ void ISR_28() { /* Port Indicator */ IOCLR=0x80; /* Transmit stop condition */ I2CONSET=0x10; /* clear SI */ I2CONCLR=0x8; /* Port Indicator */ IOSET=0x80; } /********************************************************/
If you use a NXP LPC21xx, then where did you get that "sample code" from?
Didn't the sample code specify __irq for the interrupt handler?
