How to rename the disk drive of ISP Bootloader?
I run the application code of AN10986 for invoking an USB In-System Programming in LPC1343.
I run it on keil and it works fine, during the device enumeration it contain a device name
NXP LPC134X IFLASH USB DEVICE how can I rename this disk drive, since it didn't use a string descriptor. Also how can I change the autodisk display "CRP DISABLD" into another code read protection. Also in what part of the code did the CRP DISABLD called?
Thanks.
