Hello.
I'm trying to set up a MCBSTM32C to have a Flash File System using the RL-ARM FlashFS library, but i'm having a bit of trouble i hoped someone could help me sort out.
In the book "Building Applications with RL-ARM" under RL-Flash introduction, there's a section discussing how to set up a Flash-based filesystem.
It calls out for the file FS_FlashPrg.c and FS_FlashDev.h under the folder C:\KEIL\ARM\RL\FLASHFS\FLASH then a subdirectory named according to your flash or microcontroller.
Looking in that folder i have the following folders:
25F640S33 AM29x800BB AM29x800BBx2 AM29x800BT AM29x800BTx2 AT45DB321C AT45DB642D LPC_IAP_128 LPC_IAP_256 SST39x320x STR71x STR75x STR91x
I'm not sure which one would correspond to the STM32F107VC... Do I have to write my own drivers for this controller? If so, is there literature i can obtain covering how to do this?
Thanks for any insight.
- Per
