Hi, Is it possible from startup.asm I can call the interrup service routine found in my C source file?
from my C source file:
void InterruptServiceRoutine (void) interrupt 7 //SMB { ... }
In my startup.asm:
... EXTRN CODE (InterruptServiceRoutine) ... ljmp InterruptServiceRoutine
Your response is greatly appreciated.
thanks gilmar
Yes, most processors are able to call ISR from assembler.
But the big question is why? Somehow, I think you are trying to solve a problem that has better solutions. Or solving a problem that doesn't need to be solved.
Thanks Per. I'm currently in the learning stage. Is calling it from assembler not good?
thanks again gilmar
