UV4 debugger: how to 'SAVE' to variable filename?
Is there any way to call the debugger 'SAVE' function with anything but a fixed filename? I'd like to use it in a loop of a debugger function like this:
FUNC void SaveFlash()
  for (i=0; i<10; i++) {
    ... code to fill rawFlashBuf with data ...
    exec("save c:\foo.bar rawFlashBuf,rawFlashBuf+511");
                  generate something like foo0,bar, foo1.bar, foo2,bar, etc
The other alternative is to use 'LOG' and 'd' but I don't like the output as well.
Thanks,
Andrew
P.S. I run into this again and again, UV4 is almost a great debugger, especially with the ULINK Pro, but turns into a horribly awful debugger because of the last 5% I can't get done... I wish Keil would get it over with and make a decent Eclipse plugin.
  • watch out for C string semantics, e.g. \ --> \\.
    Since there is no sprintf() builtin to generate filenames, something like
    this might help:
    Func void SaveFlash (void)  {
      exec ("save c:\\temp\\foo1.sav main +   0, main + 256");
      exec ("save c:\\temp\\foo2.sav main + 256, main + 512");
      exec ("save c:\\temp\\foo3.sav main + 768, main + 1024");
    this might help:
