Debugging "__main"
Is there any way to be able to step through the code (associated C Code) that is executed when calling "__main" from the start up file?
Reset_Handler   PROC
                EXPORT  Reset_Handler             [WEAK]
                                IMPORT  HW_init
                IMPORT  __main
                LDR     R0, = HW_init ; Initialize board: FSMC, clock, etc...
                BLX     R0
                LDR     R0, =__main
                BX      R0
                ENDP
The processor that is used as the target is the STM32F103ZE (Cortex-M3) and for some reason in a new spin of a board the system keeps on crashing in the "__main" code. It does not even get to "main()" function.
When the exception occurs I can track it down to the address of the instruction that causes this
0x080034B8   1B52   SUBS  r2,r2,r5
, but I would need to analyze more assembly code to know what it is actually doing.
Is there anyway to get the "C Code" version of this code to step through?
Is there a document that explains what happens in "__main". I would imagine basic RAM memory initialization.
  • The runtime libraries are shipped in object code form, so no, you cannot step through source code of __main.
    By the way, the instruction "SUBS r2, r2, r5" looks rather harmless. My guess is it cannot be the reason for the crash.
    It should not be too difficult to locate the exact crashing instruction by simply single-stepping through the startup code.
