sim300
hello,
I am new in this micocontroller world
actually I am interfacing sim300 gsm modem with 89c51, I want to indicate the incoming call on modem using lcd
but I am not getting how to stop reading the text, now I am using counter
means I have set the counter at 0, when there is a call on modem it sends ring continuously on serial port it creats interrupt then I an increasing counter when it reaches to 4 I am printing RING on lcd
bt for every command its nt possible to set counter every time
so I wanted to know what char does a modem sends after every ring because of which it prints ring on next line, if u check it on modem
want to grab that char and using that wants to stop reading
If any one knows anything about this plz reply me
thank you
  • 1) Doesn't the manual tell?
    2) Can't you print each character as a number to see the ordinal value of the received characters?
    3) Haven't you found quite a large number of threads already that tells what line ending the modem is using?
    4) Have you considered any possible "standard" characters that a device may possibly use when it wants to signal that it has emitted all it wants to emit on a specific line and might to signal a line feed or maybe a carriage return?
